when i go to load a file in tmpgenc 3.0, VFAPIFrameServer.exe crashes. then when i try to encode, it gets about a third of the way done and i get an address violation error in tmpgenc 3.0. has anyone had this problem? anyone know a solution?
same thing goin on here i cant load any .avi file into tmpgenc xpress 3.0 it says my VFAPIframeserver failed to initialize
i been using the prog for a few weeks and all of a sudden this happens... plz if anyone knows how to fix it
i may have figured it out. go into the program file for tmpgenc xpress 3.0, and DELETE VFAPIFrameserver.exe, then reinstall tmpgenc xpress 3.0 right over what is left in that folder. so far it is working for me.
Hello, I have the same problem and have such as you indicate VFAPIFrameServer.exe removed and then reinstalled tmpgenc xpress 3.0 right over what is left in the folder. Unfortunately I do not solve mij problem.
Krammie -
It happens to me too, I get the warning when starting to encode............my solution is to IGNORE the warning and do not press aything in the pop up box...just 100% ignore it until you have finsished working with Xpress3.
By the way I'm pretty sure its just a glitch (and it IS audio related as I convert AAC/mpeg4 audio to mp2 with Xpress and dont use Xpress for video encoding) and the end result is fine AS LONG AS I DO NOT press anything in the warning box about VFAPI
x264.exe crash in xvid4psp
By hasteroth in forum Video ConversionReplies: 2Last Post: 30th Dec 2010, 16:58 -
spumux.exe
By ranee in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2010, 10:31 -
AVI did with Huffyuv codec cause crash in explorer.exe
By PalmTX in forum Capturing and VCRReplies: 5Last Post: 15th Feb 2008, 18:09 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 09:42 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 01:38
