I installed WDM drivers which I later found out only work with NTSC
as im in the uk using PAL I have endless problems with various programs now refusing to operate in PAL and tryign to operate in NTSC
IS there a way I can completely get rid of the WDM drivers?
ive tried the HCMclear.exe and that did not work
i downloaded the wdm drivers from cinedvr website (i think)so they're not made by hauppauge
Can anyone help ive had this problem forever!
Results 1 to 11 of 11
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I just had exactly the same problem.
Remove the Hauppage entry in your device manager then
reinstall the VFW driver.
I had to do this a few times before it worked. -
Drivers may have been written for NTSC card/tuners. Send me all "inf" files of the driver and I may give you any tips.
You may also try this driver
http://sourceforge.net/projects/btwincap
But you will need to disassemble your PC and get exact model# and tuner brand/model. -
Hi
Sorry I only just saw ur replys
I tried uninstalling the card and reinstalling the divers a few times but still no luck
im using win2k
in the device manager > sounds,vide & games controller > Legacy video capture devices
It says I have Hauppauge WinTv video capture Driver and WDM windows Video capture Driver (win32)
Now I coudl swear Id removed this but it seems not
Ive tried uninstalling it from here but it wont let me If i click remove it looks like it has but if i look at the legacy video capture devices properties again its back like The Terminator or something! -
Here a Tip.
Try doing clean install and ONLY use the WDM drivers.
You know it funny most of the user I have seen only audio problem with the WDM drivers.
NO mgruber the drivers where not written for just NTSC card/tuners.
Make use you using the latest drivers.
The drivers off this page will working in the fellowing OS Win98SE/ME/2000/XP
http://www.hauppauge.com/xp/software/xp_wintvpci.htm
The date showing (Updated November 5, 2001) is wrong any way they forgot to update the date so don't worry about it.
WinTV2000 this is the latest ftp://167.206.143.11:21/Latest/WinXP/Beta/3_37_19319_Wintv2K.EXE -
ok i just clean installed those wdm drivers u mentioned
not the beta one though
This has introduced bizarre probelms in that now only the wintv2000 app is able to tune into any channels
oh and u cant use vdub to capture in wdm wihtout a wrapper
so how do i safely get rid of these wdm drivers (in win2k)so they r comletely uuninstalled which was my main objective?
You don't need the WDM wrapper
Start VirtualDub File | Capture AVI | Video | Soure then set it up.
SHS, I have the latest drivers for Win2k, though it says in device manager that's it's a VFW driver (v 3.11), Now I don't mind this as I can catch with vdub, are you saying that the WDM version will also allow me to catch with vdub ??
I'm running a WinTV PVR btw
<font size=-1>[ This Message was edited by: Shabubu on 2001-12-18 18:10:20 ]</font> -
Yes see for your self I'am test the WDM rigth now oh just plain jane drivers soon we have WDM MPEG drivers for PVR thank god and about time that if all gose well this week I keep hear a lot people where have problem with audio so I though I check them out my self so far they run just fine I can't any wrong with the audio but I do get some other problem which has nothing with the drivers it self.
http://shs-sound.paraknowya.com/virtualdub.gif
<font size=-1>[ This Message was edited by: SHS on 2001-12-18 18:36:27 ]</font> -
Thanks for the speedy reply, I'll give them ago... lets just hope DScaler works too
When I open up vdub capture the channel is never tuned in
This is after just opening and closing wintv to tune into a channel
So then I clicked source and a new window pops up and theres an option for tuning so I tell it to auto scan
I can see it skim past maybe 1 channel but it does not stop it just carries on finds no more channels then gives up
How do I get the tuning to work properly?
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 10:13 -
WDM Driver programming questions
By cybertheque in forum ProgrammingReplies: 0Last Post: 8th Nov 2008, 19:14 -
Blue screen when installing Hauppage WinTV 150 drivers from website
By ponyboy in forum Capturing and VCRReplies: 1Last Post: 5th Mar 2008, 23:55 -
Where to get WDM to VFW wrapper
By SuperFlyBaconG in forum Capturing and VCRReplies: 1Last Post: 29th Jul 2007, 10:30 -
VirtualDub and WDM Drivers?
By 1gnition in forum Capturing and VCRReplies: 3Last Post: 19th May 2007, 12:11
