Following up an earlier post with some pics.
The one with the half line is my new Pioneer DV-270. The top also has a half line but starting part way across.
Doesn't do it with all discs though. Disc in question is an Aussie show "Kath and Kim"
The 2nd pic is my 4y.o. Philips DVD-718.
This is Pioneer pic. Is this a fault ?
This is Philips pic.
The problem is the transmition because of intelaced scaning the dot has to finnish from the middle of the first frame to the start of the second frame.
You should also notice this on your recieved picture.
Some transmitions have this iregularity suppressed.
Barrybear -
So is it just a quirk of the Pioneer player ?
Didn't matter which TV I used. Got same results.
I thought perhaps my Philips was surpressing the incomplete top and bottom lines.
Looking for compact set-top DVD player
By Djinn987 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jun 2010, 15:20 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
anyone with a Pioneer DV-400,410,420 player have his problem?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Nov 2009, 10:03 -
PC drive in set top DVD player?
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2009, 14:59 -
Subtitles stick on top of each other in VLC player
By Obamargarine in forum Software PlayingReplies: 2Last Post: 24th May 2009, 12:35
