Hi
I have a avi/xvid clip which goes out of sync after converted to vcd, this is done the usual way : seperating audio(wave) then using the wave as audio source in tmpgenc bla bla. i check to see weather the original file was out of synch and it wasnt but when i did "scan video stream for errors" in VDUB 1.510, after the check, right at the bottom it said "267 frames masked (1 frames bad, 266 frames good but undecodable) what does this mean and hw can i fix it.
You should do a small test for a/v sync before fully encoding.
TMPGEnc > setting > advanced > source range
set start frame - (then about 10 seconds on ) set end frame
keep testing/adjusting audio gap as you go until you get perfect sync.
Once you have it you're then ready for the full encode - re-adjust start frame/end frame for full movie length and away you go. -
By removing the offending part of the AVI. But I wouldn't bet on it - I've tried working with and fixing bad AVIs but have given up - It's simply not worth the trouble if the AVI isn't something very special IMHO.hw can i fix it.
/Mats -
I've only had 1 AVI where bad frames knocked the audio out of sync. Here's what I did...
Encode the Video as Normal, Ignore the bad frames. Convert the Audio to .WAV fromat and load it into an Audio Editor (Goldwave is good). Find the exact place in the audio file where the bad frames are, and insert enough silence to make the audio and video files, EXACLY the same length.
I may have just got lucky, but that worked for me...
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 07:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
