My PC Locks up and i have to re boot when i use DVDShrink ( All the versions after 3.0 beta 5 )
I rip using either DVDDecrypter , SmartRipper
I open the files in DVDShrink , it goes through its initial analysis ( 1 - 2 mins ) when it finishes that it locks up
I reboot go back into dvdshrink open files and it will bring up the DVD files , everything is OK after that.
I have tried ripping with DVDShrink ( Open Disc ) and the same thing happens.
DVDShrink 3.0 beta 5 dosnt lock up for me but I like the new options in DVDShrink 3.2 and would like to use the latest version
any ideas
Results 1 to 9 of 9
Looks like a Shrink bug (since older works OK). Only option reinstall into a new dir and see what happens.
Hey Proxy
I re installed onto a new drive and that didnt fix it -
Sifaga, have you tried switching the video preview off, or changing the video renderer ("Edit >> Preferences >> Preview")?
No problem. Let us know how you get along.
I'm glad to hear it, Sifaga.
Initial subtitle timing
By Smithcraft in forum SubtitleReplies: 2Last Post: 31st May 2009, 01:25 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Green Initial screen on QT files
By rotuts in forum MacReplies: 4Last Post: 23rd Apr 2008, 19:25 -
"DVDshrink - Vista where is Application Data Analysis files located?
By mn072065 in forum DVD RippingReplies: 2Last Post: 24th Feb 2008, 17:43 -
my initial impresions of TMPGEnc 3
By vobnovice in forum Authoring (DVD)Replies: 18Last Post: 16th May 2007, 21:02
