YeahOriginally Posted by Craig Tucker
you sketch shows the cables going through the inner wall for half way, then going into the cavity. why?
Results 121 to 150 of 264
Here is a new pic for you stilt.
As you can see I would have to drill a hole in the inner skin wall somewhere. The wall is not built on the suspended floor. The floor is suspended from the wall. I drilled high enough up the wall to make fishing the cables up easy.
The cable is chased into the plaster upto a level where it is easy for me to reach into the cavity and fish the cable up. At this point it goes through a hole in the inner skin, into the cavity.
Ahhh, I see
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
@Craig - I noticed some free floating cables before you put your equipment in, that look like they are plugged into an outlet of sorts. Are those cables permanent or are they removable.
I did something similar, but put in nothing but wall plates for connections. (4 standard 120VAC outlets, S/Video, RCA, 4 speaker clips, coaxial, & RJ45) I set it up this way so anyone after me could use whatever to connect. I'll have to clear away some wires and move the entertainment center, but I'll see if I can get a pic. The cables go back to one of the bedrooms where the computers are. In the closet in the bedroom is the main breaker box, an RJ45 block of jacks to every room (something I installed), Coaxial jacks to every room, phone jacks to every room, S/Video jacks to every room, 50 speaker clips that go to every room. Many of the jacks are set in sort of a loop so I could put a stero system in the master bedroom, but set the clips in the other room to listen to music in my son's room. It's kindda cool when every TV & speaker in the house is linked to the Home Theater and you're watching a movie. It totally surrounds you everywhere. Litterally! Like I said, I'll try & grab some pics.
Which cables ?Originally Posted by Doramius
The one's in the 6th pic. Is that box permanent or temporary.
The box and shelf are one piece, it just lifts out.
Ahhh! I see. No speaker lines for surround sound? Looks like there's just power & cable/antenna hookups.
No, its only a bedroom TV.
need to send you some 6' and 4' flexable drill bits and expandable fiberglass wire fishing poles ... cats ass for putting cables through ..
http://www.mytoolstore.com/ideal/ide14-11.html
http://www.mytoolstore.com/ideal/ide14-13.html
http://www.mytoolstore.com/ideal/idendx14.html#flexible (all models)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hello,
Hatcheman - NICE WORK
OK for drywall BJ_M, but not a lot of use for brick and block.Originally Posted by BJ_M
Very nice hatchetman
That is an awsome looking setup HM. 8)
Originally Posted by lordsmurf -
It's a little embarrassing posting a pic after HM's awsome looking setup but here goes.
Is that a bad angle, or is that shelf starting to bow?
Nothing can stop me now, 'cause I don't care anymore. -
That would be a bad angle or maybe a shadow effect on the wall.Originally Posted by ViRaL1
Originally Posted by jimmalenko
I just looked at the original closely and it is a shadow, it has a low point in the middle because that is a corner where the 2 walls meet directly behind the tv (I know it is hard to tell because it looks like one wall but it is a corner.)Originally Posted by lordsmurf -
Very nice!Originally Posted by HatchetMan
Can you post them or email some of them to me? My dad is working on building his own theater system setup into his house and would be very interested to see what you've done.
jml [at] fervorstudios.com
Hello,
gummyavenger - NICE
Lucky dog you - 6.1 eh???? How is it???? MOre atmospheric with the extra channel????
Yeah I like it a lotOriginally Posted by yoda313
...although it's tougher to find movies that are encoded for 6.1 than I though it would be
Home Theater
By Al27 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2011, 18:37 -
WDTVLive VS Home Theater+ ???
By boofus in forum Media Center PC / MediaCentersReplies: 6Last Post: 30th Mar 2010, 01:15 -
Home Theater Projectors
By Lucifers_Ghost in forum Off topicReplies: 17Last Post: 18th Sep 2008, 02:36 -
all in one home theater systems
By CODEWERKX in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2007, 12:09 -
Is your home theater organized?
By yoda313 in forum PollsReplies: 19Last Post: 28th Sep 2007, 08:21
I'm speechless Hatchetman. That is very nice.
