I know most americans haven't a clue what a £ is worth, so online i always do the dollar conversion.
I bought a Sanyo set, so i think that makes it japanese![]()
Results 91 to 120 of 264
Here is what I have just done in the bedroom in our new house.
Cheers mate, I am well pleased with how it came out. Its just when you start and are standing in a pile of rubble you think to yourself why am I doing thisOriginally Posted by glockjs
I'm particualrly impressed with the 2 10 ton jacks to lift the 50 lb. block of cement.
It was the easiest way I could think of to hold the lintel in place. Hardly any load required but it was a lot easier to jack it up than jam wedges underneath. Also meant I could cement the lintle in unhindered.
As I said I'm impressed..... Whatever works. I have 50 ton house jack here if you ever need it. You know if you needed to lift mre than 2 or 3 blocks. :POriginally Posted by Craig Tucker
Only 50 tonnes
I don't have a picture at the moment but here is my setup:
DVD Player: Pioneer DV-K301C. It is very nice and have had it for over 4 years now. It has 3-disk carousel, plays all regions, NTSC or PAL and senses voltage automatically. Purchased it in UAE.
VCR: Sony. Forgot the model but again is 6-head multi-system. Have had it for over 10 years now. Purchased it in Sydney.
Receiver/Amp: Onkyo TX-DS747, 100W RMS front, 50W RMS Rear and Center. Does not have DTS. Purchased it in UAE.
Speakers: Bose Acoutimass AM-10. Purchased it with the Amp in UAE. Have been very satisfied with these. Size was the main consideration.
TV: LG Flatron 29 inches. Purchased 3 years ago in India. But will soon be going in for an HD rear-projection model soon – maybe 52 inches.
Regards*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
Nice work CraigOriginally Posted by Craig Tucker
Wow, you guys have some thick walls there. If we did that here, the backside of that TV niche would be protruding into the next room ..or outside :P
Beautiful job ...very professional-looking work 8) -
Thanks cap, its only that thick because it used to be an external wall. It is now internal because the house has been extended. Generally internal walls would be single skin blockwork or stud wall and plasterboard, which would have meant I could not of done what I have. External walls here are pretty much all twin skin with a cavity.
Ahhh, that explains itOriginally Posted by Craig Tucker
Have you had any formal training in doing that sort of work, or did you just wing it like I usually do? -
No formal training, just had a crack at it. This is my first hole in the wall
I will always have a go at things myself, being educated as mechanical engineer helps and working at a university there is always someone with the knowlege I am after if I need any advise. -
Craig, what model philips is that TV? It looks exactly like the one I am getting ready to purchase. I took your advice and decided to go with Philips BTW.
Its not a phillips its a relysis. Would have preferred to go with a phillips obviously but they were just too much money. Its only a bedroom TV after all. And I am very pleased with this one - so far.
Here is mine - not very elegant but functional all the same and works for me:
Rear View:
Rear View with Panel open:
Rear Panel Door:
Components:
Could do with a duster in there mate. :P
The cables are chased into the outer skin wall plaster from floor level, through a hole I drilled in the outer skin then fished up inside the cavity.
Here is a sketch
why not just drill the hole in the cavity space?
Why go through the inner block(?) wall? -
You mean up through the suspended floor into the cavity.
Home Theater
By Al27 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2011, 18:37 -
WDTVLive VS Home Theater+ ???
By boofus in forum Media Center PC / MediaCentersReplies: 6Last Post: 30th Mar 2010, 01:15 -
Home Theater Projectors
By Lucifers_Ghost in forum Off topicReplies: 17Last Post: 18th Sep 2008, 02:36 -
all in one home theater systems
By CODEWERKX in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2007, 12:09 -
Is your home theater organized?
By yoda313 in forum PollsReplies: 19Last Post: 28th Sep 2007, 08:21
