proxyx99 here are the results
https://www.videohelp.com/forum/viewtopic.php?p=1024711#1024711
Results 31 to 36 of 36
what Nov. 1 vote ?
Check back redited post (to make it clearer).
Appreciate the work you have done. The image(s) you posted is just one big blur. Hardly suitable example to judge the results. -
things like waterfalls , heavy rolling/blowing fog/smoke, fire/explosions and other such type very fast moving massive particle effects are the worse thing to throw to a mpeg encoder ...
just about all of them will choke at dvd bit rates if you look at it frame by frame - but in the whole scheme , can look alright ...
the downside is, of course, all the above WILL look like a blur because that is what they are ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
The idea is clear but there"s more to the picture quality then what can be inferred from submitted frames.
d_unbeliever: I like to throw in my comment on the speed-thing... I sometimes frameserve with virtualdub-mpeg2, and its slow compared to AviSynth, so you lose the advantage of faster encoding. The Levels function in avisynth is compatible with virtualdub Levels, so just transfer the numbers from virtualdubs Levels into the avisynth script to speed up. My experience is however that also avisynths Levels is kinda slow, so it will not help very much, but im sure you'll notice the difference. Also, Levels is different from brightness/contrast, so maybe you will not like it anyway.
Adjust contrast on short video?
By heyjjjaded in forum EditingReplies: 19Last Post: 28th Sep 2009, 08:36 -
How to adjust Color/Brightness/Contrast/Etc in firewire camera?!?! PLEASE..
By vegassteven in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2008, 07:54 -
Software to adjust Color, Tint, Contrast.............
By richards2222 in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2008, 05:57 -
Video editing of brightness and contrast?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 6th Feb 2008, 19:31 -
Fixing brightness/contrast on a DVD
By Salva Veritate in forum EditingReplies: 4Last Post: 7th Oct 2007, 21:05
