I have 2 movies that near the end keep glitching out and freezing, I watched these 2 movies on my computer from the file on my hard drive and never came up with this problem, any ideas on why it keeps doing this ?
Results 1 to 25 of 25
I had this problem when i was using cheap accu dvd media, all of the movies burned on those discs always messed up at the end, therefore i only use riteks now, maybe that is the problem?
actually its not necessarily the media... I had the same probelems too oon some good high quality media... I found out that at the ends of the DVDS the quality is quite poor... so compress the files a little more so they dont fill up the whole dvd
I only use
4200 mgs when I make movies and it fixed the problem easily with little distortion to the movies -
So you had quite poor high quality media?
He's a liar and a murderer, and I say that with all due respect. -
I agree with Feel, and this is the exact same technique/method when I burn my DVDs. ( I sometimes go to 4300MB ).Originally Posted by fee12345It's time to kick some butts, and presto ( if you know what I mean )
I'll try that guys, the media I am using is fuji so I don't think its the disc. Also what are other ways to shrink the size of the movie your downloading, I know frame rate shrinks them drasticly, anything else ????
I had that problem and it was my FAT32 harddrive causing it. I was able to solve the problem by using Img Tool Classic to make segmented image files for DVD Decrypter to burn.
Darryl -
So what should I shrink down ? I though the dvd-r had 4.38 gm not mb, sorry if the conversion for mb is that, I'm not good with computers. Anyways should I shrink the frame rate down ?
Often times you won't come across those problems on your computer because computer dvd drives are far more capable of reading so-so discs than stand alone dvd players. Cheap and/or poor media tends to have problems near the edges. Either get better media, or don't burn all the way to the edge.
Originally Posted by jimmalenko
Ditto.
Please see Gurm's Theory on Blank Media for more information.
Where can I find this, by the way I can't use dvd shrink because it does not support avi files.Originally Posted by indolikaa
Use decent media and fill the disc.
I could not find fuji on that website, I found the creators and it seems like decent media.
What's FUJI ? ID or brand
FUJI = WalMart
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Fuji = Staples (in Canada)
Speaking of which, they have a sale on the 5 packs that nets you a $5 rebate per pack. Friday August 27th they have a midnight madness sale so they may end up with lots of cheap(er) stuff. I'll have to go and see... -
Originally Posted by 90blackcrx
See www.nomorecoasters.com. That will give you a good explanation of what happens when media doesn't work right. -
i never have any bad burned.. (burned over 100dvd-r)..
Sonic 1-2X(Must001) (hacked the Nec 2500A to burned 4X) check over 50time with DVDInfoPro and got no error.
$19.50 for 100media i can't resist.. -
I actually laughed out loud when I read thisOriginally Posted by fee12345
Shrink the DVD you author before you burn it! You can't just burn AVI files either I think.by the way I can't use dvd shrink because it does not support avi files
So convert to Mpeg, author your DVD, shrink the DVD you created, burn that. I do it often because I sometimes capture more than I plan, just playing around, or estimate the time and bit rates wrong, and my dvd turns out just a little too large.
It works for sure. -
Not a media problem the high quality disks are poor quality??
OOO KKK
If you say so.
But I have had a good high quality disk that played perfect 9/10 times, but once it started the movie really slow, jumpy, jerky! Nothing like stop, fast forward or rewind would fix it. I opend the tray, closed the tray, it worked perfect. I never touched the disk! Never had any problems before or after with that player either, so what was that??
Both player and DVD worked perfect everytime it's ever been used, except that once!
Any ideas on choosing a good NAS device to store movies and such on?
By ryangarfield in forum ComputerReplies: 0Last Post: 20th Nov 2009, 09:57 -
Ideas for home movies DVD background music??
By Grunberg in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 17:58 -
Why are my movies freezing?
By bigmatt72401 in forum DVD RippingReplies: 10Last Post: 6th Aug 2007, 06:41 -
My DVD Film backups are 'freezing up' near end of Film
By Artom in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2007, 04:01 -
Backup DVD Freezing At End Because Of Size
By medlinwsp2m in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2007, 02:52
