  1. Guest
    Guest
    Just hooked up my FW card and chose the XP movie maker to capture. Is this a stupid way to go? I chose best quality. Do other programs allow for a higer rez? I just want to crop some video,so is this program for retards? I dont want to miss the boat ,but I like the ease of this program. I do have Vegas,but it seems like a pain for general use.
    p.s. there is an option on cam to record at a setting that will allow to add two audio tracks.Can I do it with XP MM?
  2. Since you say firewire card, I'm assuming it is DV.
    WinDV is a simple, but effective capture app for DV. For editing, Ulead Videostudio is easy to use.
    Windows XP Movie Maker is extremely simplistic.. not much good.
  3. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    There is a DV option in WMM, which is much better than "best quality". If not, update your copy of WMM.
  4. I would not suggest the Windows XP Movie Maker for other reasons however; it is an extremely limited piece of software.
