  1. Anonymous
    Guest
    just installed my fw card.Manual states that xp should recognize the new device on power up.no dice. troubleshooting tips.
    1.card inserted snugly-yes
    2.ports active on the card conflicting with the equiv ports on the pc.
    How do I check #2?
  2. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Did anything at all pop up when you first powered on the system after physically installing the card? Also, check Device Manager and see if you see anything new, or anything with a Question Mark.
    Nothing can stop me now, 'cause I don't care anymore.
  3. Originally Posted by Dr.Gee
    How do I check #2?
    Does it show up in the device manager?
    Does it show up in the device manager as a yellow question mark?
    Card manufacture and card chipset?
    we'll work from there first
    Originally Posted by jagabo
  4. Anonymous
    Guest
    Sorry guyz.It was #1.
  5. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Sometimes you just have to make sure it's shoved in there nice and tight. THEN things will start happening the way you want.
  6. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
