Hi all,
I burned a VCD with Easy CD Creator 5 using all the guides on this site (which are very helpful, thank you). I started with an avi. Created an mpg - VCD (standard) in TMPEGenc. I made sure to select finalize on the burn. When I put it into my DVD/VCD (it says so right on the front!) it trys to load and reads "no Disk". What's up with that! It plays fine with a VCD software player on my computer.
Any ideas would be greatly appareciated!
Joe Gotelli
Maybe your DVD doesn´t play CD-R??
What kind of DVD do you have? Maybe take a look at the
DVD Player compatibilty list.
fitte -
Thanks for responding, I appreciate it.
I have a Samsung DVD Player which is supposed to support VCDs. It says it plays VCDs right on the front of the player. That is why this boggles me. Especially since I can launch VCD Player on my computer, click play, and presto it works.
Joe Gotelli -
Most DVD are able to play VCD´s. Some DVD Player do not
play CD-R. The VCD that plays on your PC is this a "burned one" or a original?? My first DVD wasn´t able to play CD-R so i looked for a other one.
Toshiba player disk error
By Buzzword in forum DVD & Blu-ray RecordersReplies: 4Last Post: 23rd Oct 2009, 11:40 -
Disk Read Error on My Laptop
By The Monkees in forum ComputerReplies: 6Last Post: 25th May 2008, 22:35 -
Disk read error....
By rubberman in forum ComputerReplies: 12Last Post: 12th Feb 2008, 14:06 -
burning error/disk eject
By djspud in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Jul 2007, 14:15 -
Error burning .mpg files to DL disk
By Slowburn in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 07:11
