Please, if ayone knows a good, but functional region hack for my DVD Player, so I can play DVD disc with region code 1; my DVD Player is set to region 2. What are the steps of setting reg. codes for others zones.
As I said, my DVD Player is : LG LH-D6430
Thanks,
DMS
darkos18,
Below you have two posibilities. Make your choice:
LG LH-D6430 2 user hacks Add hack January 15, 2004 Click here for DVD Compatibility
Region code hack posted by Jaymz, December 21 2003:
1. Download 6000.zip from lgregionfree.tripod.com, small file (4kb)
2. Burn the whole DIR (RMTM0000) to a CD using Nero Burning ROM (ISO Level 1, Mode 1, ISO 9660)
3. Insert the burned CD into the dvd, wait for the menu on the TV.
4. Press "0", then "PAUSE" and after that turn the dvd OFF
5. That's it !!!, REGION FREE.
Region code hack posted by Dulux, January 15 2004:
1. Plug LG DVD player (no disc in tray) in and turn on with REMOTE.
2. Wait for "NO DISC" message.
3. Press the open button on the remote.
4. Press the following sequence(using the REMOTE only) PAUSE, 3, 1,4, 1,5, 9
5. Wait for "CODE__" to appear. Enter 0 (all regions) then press PAUSE then press POWER.
The unit should turn off leaving it region free, but be warned that it have trouble with Region 0 discs. If so just redo the above steps and at "CODE __" enter your region.
--------------------------------------------------------------------------------------Good luck! -
I have tried this but no CODE_ apperas on the screen !
Ok, let me ask this one more time !
Let's say I want to watch a DVD movie with Zone 1 onto the DVD player with Zone 2. How can I do that without doing any buring and stuff before; or it is really necessary doing that Nero Burning first ?!
Please reply, I will be very greatful !
Thanks,DMS
region code hack
By elpini in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2025, 18:29 -
LG HX751 Region code hack
By jantje in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Sep 2011, 12:25 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Region hack code
By Shopgirl in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Dec 2010, 18:39 -
Region code hack
By xandru66 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 19th Aug 2009, 07:11
