I have an avi file and srt sub. How can I create a permanent sub using either avisynth or aviscript? I don't know anything about the 2 programs. Must I use virtualdub to frameserve or better still can I directly load the avs file into tmpgenc for encoding?
The reason why I chose this method is because when I tried to frameserve
from virtualdub using the default textsub filter in virtualdub, tmpgenc will
report as file unsupported.Please help!!
Results 1 to 11 of 11
Can someone post a simple script, just the avi file and the srt file and all the essential dll. Would appreciate very much. Thanks
Dude, did you read that thread? seemed like there was plenty of examples and discussion on how to use it.... tis where I found out about it.....Originally Posted by Drakng
When I get home tonght, I'll dig up what I have used in the past... As I recall, it is fairly straightforward..... biggest PITA was geting the sub file in order... Subtitle Workshop seems to ring a bell..... it will be at least 4-5hrs before I can get to it though... -
OK... sorry for the delay.... long day at work.....
I guess there was a bit of confusion as the package that the VSFilter.dll is part of is called TextSub. Here is a link to it on WarpEnterprises. This package has a full set of instructions on how to use it. If you have any furthur questions, let me know....
T -
Yeah.. I read the tread but it doesn't seem to apply in my case.Textsub is
already provided in virtualdub. I don't know how to write the script and the
parameters required.
I just need a simple script for a avs file so that I can directly loaded it in tmpgenc or VD...Please help. -
This sample uses a DVD2AVI project as source and the textsub filter that's part of VobSub, and uses .ssa, but .ssa is easily converted to .srt if it doesn't handle srt natively.Code:
LoadPlugin("c:\program\dvd2svcd\mpeg2dec\mpeg2dec.dll") mpeg2source("c:\y\xyz.d2v") LoadPlugin("C:\Program\VobSub\textsub.vdf") textsub("c:\y\xyz.ssa") LanczosResize(352,288)
/Mats
New AVISynth UI
By tin2tin in forum Latest Video NewsReplies: 23Last Post: 19th Jan 2012, 02:53 -
Aviscript
By kemo1000 in forum EditingReplies: 4Last Post: 14th Jan 2012, 09:43 -
AVIScript Line25 error
By pboong in forum Video ConversionReplies: 25Last Post: 24th Aug 2010, 07:35 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 05:36 -
AVIsynth help!
By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 04:35
