How do I burn mpg files? I've copied to the hard drive using Womble, but can't do anything with them now. Do I have to author, if so what should I use? I'm trying to use Nero, but it won't recognize files. Is there anything on the subject here? I can't find anything.
Results 1 to 9 of 9
That's where I've been looking, can't find anything. Everything I've tried says illegal file or something to that effect.
If you are trying to burn a dvd, then yes the files have to be authored.
Try using TmpgDvd author -
see 'encoding' and dvd specifications then ....
1. capture
2. encode
3. author
4. burn"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
What r u trying to do? Burn them to a DVD that u can play on a standalone? Or r u trying to burn the raw mpg files to a disk (cd-r or dvd-r)?
The distance between genius and insanity is measured only by success... -
Trying to burn them to DVD-R to play on a standalone. Everything I try to use says illegal file or something like that. They are from DVD-RAM recorded on a standalone with the VBR on. Is the VBR the problem? The recordings are old and it is too late to do anything about the VBR now.
when you give out such little info and just now mention the source was from PVR , it is very hard to give any good advice
I'm new to this and don't know what anyone needs to know. I've been trying to get from RAM to DVD-R for 5 days now. I actually burned 1 disc, but when it got to the standalone edit point the audio went off by 4 seconds or so.
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 23:18 -
burning 300 mpg video files on DVD?
By twister6 in forum Authoring (DVD)Replies: 3Last Post: 2nd Nov 2008, 20:02 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 18:36 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
Error burning .mpg files to DL disk
By Anonymous4374945 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
