Hello - new to this forum and could not find this topic discussed previously.
I have been converting a number of VHS tapes to DVD over the past year on my Philips DVDR 75. I continue to have a problem with a sort of high pitched electronic "chirp" sound when recording certain VHS tapes with loud passages, to DVD+R/RW.
There is no recording level adjustment on the Philips 75, so I cannot reduce the input levels. I have tried filtering the sound through an equalizer to reduce the db levels, but I need to reduce the levels so dramatically that the end result is a DVD with sound levels that are too soft. I've tried replacing the cables, using different VCR's, etc. but still have the same problem.
Any help would be greatly appreciated. Thanks!!
Hmm, is this related to my tuner problem? I'm not sure if the sound is the problem, or if it's something else to do with the signal.
Sound distortion when play CD on Magnavox ZV457MG9A
By AliceWonder in forum AudioReplies: 1Last Post: 12th May 2011, 12:16 -
Audio Distortion Recording from only one TV Channel
By Pierre Sonar in forum DVD & Blu-ray RecordersReplies: 3Last Post: 24th Sep 2010, 16:29 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
Philips DVDR 3330H recording codec
By yangp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Jan 2008, 09:51 -
Philips PET725/78 - Distortion when .avi is "wider" than wide scr
By xXxAlvoxXx in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Jun 2007, 13:37
