Hello
I Import QT files with my AlchemyDVR card. they are QT files comp. with sorensen3. they run about 2gb for 30 minutes of TV
the app quit before the end of a program, and I have a file (QT) that is 1.8 GB so its most of the show.
QT the app will not open it, says unknown file. FinalCutEx also won't import it, unknwm file.
iMovie says this: Can't be imported. QT coun't parse it. -2048
is there any other app out there that can rescue this file and make it readable with QT?
Id like to use this problem as a way to learn more about movie files, qt etc and rescue this also.
thanks rotut
I'd say to open it up with HexEdit, along with another .mov that the DVR card made, change the broken one to have the same beginning as the one that works. I once had a DV file that had a bunch of zeros at the beginning, and wouldn't open with QT. Removing them all, until it had the same header (beginning of the file) as one that worked fixed the problem.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
end of file--Adobe Encore
By koberulz in forum Authoring (DVD)Replies: 19Last Post: 18th Oct 2016, 20:21 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Playback with MPCHC while still capturing stops at old end of file
By suppa in forum Capturing and VCRReplies: 0Last Post: 30th Dec 2009, 14:11 -
cutting the end of xvid file
By eric123 in forum EditingReplies: 1Last Post: 29th Jan 2009, 14:13
