Hi,
All
First up...
This only happens on some svcd files.
I extract the mpeg from the svcd with iso buster.
then put the 2 mpeg files thru tmpeg to get my dvd file.
Problem being when i play the file it is out of sync?
Now i have done this about 50 times and no problem just seems more recently more svcd files are out of sync after going thru tmpeg.
Should i encode both discs seperately to have 2 dvd compliant files then put them into tmpeg dvd source creator as 2 seperate files?
Hope this makes sense.
RS
Results 1 to 14 of 14
Been reading it could be to do with demuxing the audio?
How do i do this and is it the original svcd mpegs i demux or the
mpeg2 file tmpeg created.
RS -
Hello,
You could use tmpgenc. File - mpeg tools - demultiplex.
You could use either the original svcd or the new mpg file. You want to get the audio out of it.
Kevin
--it will be saved as an .mp2---Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hi,
Yoda
Thanks then do i just add the audio and mpeg2 file into tmpeg dvd author
and make a vob fiel or rencode in tmpeg source creator?
Sorry for the dumb questions
RS -
Hello,
That would be a good way to try it out.Thanks then do i just add the audio and mpeg2 file into tmpeg dvd author
and make a vob fiel
Kevin
---No dumb questions here, as long as you do a little reading first!! (which, thankfully, you did!)----
[/quote]Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
will try that when i get home from work!
Let you know how i get on..
RS -
Hello,
Also, you may want to start over and check out these guides:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=SVCD+to+DVD&...or+List+Guides
They are svcd to dvd.
Still cannot get it in sync.
This only seems to be on the second part of the film.
Extracted the audio in Virtual dub then added the auidio and mpeg to
Tmpeg and encoded again and it still never worked.
Cannot seem to find a guide to help me demux.
As i do not know what i am doing with it?
RS -
OK this may or may not help...it depends on your DVD player but it works for me every time.
1. rip your file to h/d
2. TMPGenc - load in audio only. Reencode as Audio 48000, 224 bit stereo
3. TMPGenc DVD Author
4. Load your ripped file then load your new audio file.
5. Author to h/d
6. Cyberlink PowerDVD to test
7. If ok, BURN
Works with CYBERHOME DVD Players + PACIFIC DVD Players + PHILIPS DVD Players.'It isn't easy having a good time .... even smiling makes my face ache' -
Ever tried SVCD2DVDMPG? 100% success rate in SVCD (1 or 2 CD) to DVD conversion. Then author with whatever.
/Mats -
Not all SVCDs are created equal...Originally Posted by reignofsound
/Mats -
Most DVD players.Originally Posted by reignofsound
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Mkv Audio sync problem converting to DVD
By yudopplyr in forum Video ConversionReplies: 14Last Post: 10th Dec 2011, 15:55 -
DVD Flick audio sync problem?
By neo*2 in forum Video ConversionReplies: 4Last Post: 6th Sep 2009, 14:51 -
MKV->DVD Audio/Video Sync Problem
By Maikeru-sama in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 19:32 -
HD dvd conversion, audio sync problem...
By BigJeebz in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 22:52
