what is the best program to put data onto a dvd+r i have nero 6 but it doesn't work i tried burning 3 times all write errors i have a plextor px-708A dvd rw is there another software which can do this or is it my dvdrw
thank u for ur time
Nero is great, sounds like a user error. :P Have you tried burning at the slowest speeds?
DVDDecrypter... Or take a look under tools. But actually, Nero works fine for writing data to DVD, at least on my system...
/Mats -
"what is the best program to put data onto a dvd+r i have nero 6 but it doesn't work i tried burning 3 times all write errors i have a plextor px-708A dvd rw is there another software which can do this or is it my dvdrw
thank u for ur time"
Can I get a period or comma please?
Sounds like user error or media. -
i have burned it at a lower speed, it only gets to 50% then it says writer error. the media i'm using is memorex dvd+rw 4x, if that helps is there another software i could use that is just as good as nero for burning data or movies thanks
program
By maxone71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2011, 06:23 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 13:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
which program?
By MONSTERTITO in forum Authoring (DVD)Replies: 1Last Post: 1st Oct 2008, 13:30 -
Does anyone know a program that does this?
By dcsos in forum AudioReplies: 6Last Post: 10th Jul 2007, 07:05
