hey...
I am converting my files from avi to rmvb. In order to do that i need to use ffdshow becuase of some sort of codec that is inside. When i use ffdshow it crashes the program for some videos. So i play with the settings that are in the ffdshow and it will enable me to encode 1 or 2 shows before it crashes to another video format.
Is there a standard setting that i can use? i have tried alot of versions of ffdshow already. can someone recommend a stable version or a better codec to replace ffdshow. thx alot
deos anyone know how to solve this?
or does anyone know what are the ffdshows that is normally used to encode the anime files?
BD-RE and ffdshow
By ttheb1 in forum Blu-ray RippingReplies: 12Last Post: 30th Jan 2011, 00:10 -
ffdshow is insane
By El Heggunte in forum Off topicReplies: 4Last Post: 9th Oct 2010, 13:36 -
What is FFDshow?
By terrypin in forum DVD RippingReplies: 11Last Post: 7th Apr 2010, 18:26 -
using ffdshow with??
By uglijimus in forum Video ConversionReplies: 7Last Post: 19th Aug 2009, 00:55 -
What is ffdshow and should I be using it?
By Hank Kinsley in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2007, 01:52
