  1. Ok my problem is that i have to wait ages for ulead dvd factory to convert my mpeg files before it finally burns them to disc why is this? is there a quicker way to covert the mpeg files? what exactly is the coversion from and to??
  2. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    Gally56,
    I'm taking for granted that you are adding MPEG2 files to your DVD project.
    If so check the following in order to prevent MovieFactory from re-encoding your Mpegs:
    1. Click on the "Project Settings" icon.
    2. Ensure that the "Do not convert compliant MPEG files" box is checked.
    If your MPeg files are DVD compliant then MovieFactory will no longer re-encode them - saving you hours of waiting. Plus the re-encoding can degrade the quality iof your Mpegs !!
    Good luck,
    Moonstomp.
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
    Mar 2003
    Saint Symphorien, Belgium
    Hello,
    Moonstomps is right : when the files are DVD compliant, they are not re-encoded, thus not degraded.
    DVD compliant means both video (MPEG 2, 720x576/720x480 max 9800kbps CBR or VBR) and audio (48kz, 16 bit, up from 192 kbps) compliant
    So if your file contains 44,1 khz audio, DVD moviefactory will re-encode it, including the video...
    Best regards
    jacobus
    Be yourself and be happy in what you do
  4. Ok so I've checked the MPeg files and they are 480 X 576 44100hz bit rate 224 now to convert them at a quicker rate what software do you recommend and is their a guide on here for it.
  5. Your audio file is at the wrong sample rate. it should be 48KHz, not 44.1. You can re-encode with BeSweet.
