  1. i been encoding from divx and xvid to svcd for a year or two. gettin fed up with burning 2 cds n changing it while im watching it i bought a dvd burner,, now im encoding from xvid, divx to dvd, and ive done about 3 so far and all came good
    however i do have 1 question
    i always save the wav with virtual dub and make the compression on "no compression"
    and then conversion to "44.1"
    (default is 48)
    now for my understanding that is downgrading it right?
    if it isnt.. correct me.. basically i want to ask do i still need to convert to 44.1 when encoding from divx, xvid to dvd just iek i used to with divx,xvid to svcd
    thanx in advance for the help
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    The correct sampling rate for DVD is 48 KHz.
  3. o shit...
    so wat diff does it make??
    so i shold leave them as a 48 kz
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    The difference is 48khz is the Dvd Standard for audio. It must be used to be fully compliant.
    Kevin
  5. ah i see
    any difference in quality?
    cause ive noticed when i encoded from xvid to dvd (700mb) to (4.2gb)
    i noticed a decrease in quality of sound
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Any time you convert something there is a little quality loss. Your best bet would be to go back to the original source and start over - if possible of course.
    Kevin
