I am trying to find a Mac DVD Player program that is free and can take snapshots of DVD Menu's and whatever you put into the DVD Player on the computer? Is there one out there like that?
In OS X there is a way to just take a snapshot of anything that is on the screen (desktop)
Mac OS X: Shortcuts for taking pictures of the screen
In addition to the Grab application, you can also use keyboard shortcuts to take pictures of the screen in Mac OS X.
To take a picture of the whole screen, press Command-Shift-3.
To take a picture of part of the screen, press Command-Shift-4 and drag to select the area you want.
The picture is saved as a TIFF file on your Desktop. Note: Mac OS X 10.2 and later saves pictures as PDF files. See document 107078 "Mac OS X 10.2: Screen Shots Are Saved in PDF, May Be Converted" for additional information.
To copy the screen capture to the Clipboard instead of saving it as a file, press Control-Command-Shift-3 to copy the entire screen to the Clipboard, or Control-Command-Shift-4 to copy the selected range to the Clipboard. -
BernieR, you are correct in everything you said, but it won't capture the window that the DVD is playing in. There is a utility called Capture Me that will capture a still of a DVD menu (or a still of part of the movie). Just google "Capture Me" and I'm sure you'll find it.
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon -
I've used an app called DVDCapture it saves as a pdf or jpeg. You can find it at MacUpdate. It also has a controller so you can play, pause and advance the dvd, which is helpful in finding the right frame.
use VLC to play the DVD and you can use the built-in capture to get it.
ex: http://img.photobucket.com/albums/v18/davedecay/goosnargh/spz2.jpg
dk
DVD authoring program for mac
By BIFFtheSTIFF in forum MacReplies: 2Last Post: 25th Apr 2011, 02:23 -
Mac....which program(s) would be best?
By JonnyPhoenyx in forum MacReplies: 6Last Post: 3rd Nov 2010, 18:34 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Your program preference on a mac
By gooberguy in forum MacReplies: 7Last Post: 18th Jul 2010, 03:28 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13
