Between DVDLab and TEMPGenc DVD author, which one is better to use to create a DVD movie disc without any problems???
I would have use ULEAD moviefactory if they had allowed me to Create DVD menus without Chapter windows in the menu.
I have decided to use the predessors because they allowed me to create DVD menus with the word "Play All" instead of the ugly chapter windows DVD menu enforced by Ulead Moviefactory and the other proprietry ones.
Or is there any way to get rid of chapter windows in DVD menus when using Moviefactory???![]()
Results 1 to 16 of 16
I think dvdlab is hard to beat. You can create just about any kind of menus. It is also compatible with photoshop for importing photoshop files and useing the layers as buttons. It can also do almost as much as photoshop just by itself. You do need the professional version for subtitles but I believe that tmpgenc does not support subtitles either. If you need an ac3 encoder then you can buy just the ac3 encoder from tmpgenc for $30 and put your ac3 audio into dvdlab.
I can only speak from (in)experience with TDA...(only used it a couple of times-didn't like what I got...) and vouch for DVD-Lab.
probably very true...but I (personally) don't need the AC-3 encoderOriginally Posted by Supreme2k
I have been very happy with DVD-Lab (been using it since its beginning, and am now using ver 1.3).
no need to create chapters...just make the "movie" as the first play option...
my 2 cents...
mastersmurfiejust a thought
mastersmurfie -
I am use DVDit now. No subtitle and moving icon.
Its working fine and have no complain. DVD Workshop will be the next step. Scenarist will be ultimate.
Thanks fellas, DVDLab and TDAuthor has superb DVD menu creating abilities. But in creating a DVD movie, I reckon Ulead Moviefactory is superior. If it wasn't because Ulead Moviefactory enfore chapter windows in it's DVD menu I wouldn't use DVDlab or TDA at all.
I was wondering if I could get rid of the chapter windows in DVD menus when using Moviefactory and how ??? Or could I import Photoshop menus into Moviefactory???
Try both and form your own opinion.
There is a reason why God gave us one mouth and two ears!!! -
DVD-Lab pro has a feature to plug-in an AC3 encoder.
I like DVD-Lab Pro, just gives me a better "warm-fuzzy" than TMPGEN DVD Author. -
You can use the TMPGDvd Author ac3 encoder as a standalone if you wish - it's what I do anyway (drop the wav into the encoder and out comes the ac3)
TDA is not that good menu-wise. Nice simple program, multi VTS, lenient on source.
DVDLab is complex, can be buggy, not always compliant, but can make some nice menus.
I have TDA installed on my system for VCD work. No DVDLab here, not past expired demos. Not appealing enough to me.Want my help? Ask here! (not via PM!)
i like the fact of the menus you can make in DVDLab, but i like the video features in TMPGEnc DVD Author, if there was a way to make menus like DVDLab's in TMPGEnc, then id be all set with my authoring
It's called ULEAD DVD WORKSHOP 2. 8)Originally Posted by Invader BugsWant my help? Ask here! (not via PM!)
Tda`s ac3 is dolby digital but its 2.0 and 5.1 isnt supported.
It is certified! It cannot display the DD logo if it wasn't. A steal in the video production (consumer) world.Originally Posted by fmctm1sw-----------------------------------------------------
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 22:15 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35
