  1. i went to burn some music videos(mpeg 1) as a vcd disc and toast went ahead and reencoded EVERY damn file!!!!!...it took over 1 1/2 hours to finish this.....as far as i know there isn't a way to turn encoding off so i may go back to 6.03 which DOESN'T encode a file unless it needs it...
    7th layer of hell
    or u can just use vcdtools and make the videos into bin/cue first...
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
    Jun 2001
    Silver Spring, MD USA
    Whenever Roxio "updates"/breaks Toast, I keep two versions on the computer, just in case something like this happens...
    Dec 2003
    Eugene, Oregon
    I just tested this with a VCD-spec MPEG1 video and Toast 6.0.7. Toast did not re-encode the MPEG1. There was a multiplexing stage and then the burning of the VCD.
    My guess is the MPEGs you have are not the same spec as Toast uses for VCDs so they were re-encoded to that spec.
  5. Toast 6.0.7 actually accepts even more MPEG's then 6.0.3 without re-encoding, especially MPEG-2 with very high VBR bitrate. If they don't work in 6.0.7, chances are they are to far out of spec for a VCD. My guess is the bitrate on the files are all way to high for a standard VCD and Toast has to re-encode them.
