I'm having problems with MPEG-VCR. Periodicly when I cut comercials the video and audio are out of sync. Since I only get this periodicaly on long recordings (sometimes several hours of recording) I don't see this all the time. I'm having a hard time finding a pattern that I can repeat. Once I have a recording that when I cut comercials the video and audio are out of sync I can repeat it.
Since I've noticed this problem I've been using my the program "TEMPGEnc DVD Authoring" to cut comercial. But it will only cut on what I think is the begging of the GOP frame and it would be nice to have a finer trimming ability.
I've been grazing here for several months now getting ideas on what software to use and what final format I want. I've searched in the past for answers to my problem w/o any luck.
I've had my AIW7500 for over 1 year and recorded shows for later viewing (before I got a PVR). Now I'm trying to put shows on DVD at a reduced quality that I find acceptable. I can get 8 1 hour episodes/DVD w/ the format I've chosen, and it is better than my VHS tapes to boot. I consider myself to be a novice re: copying to DVD.
I've used the information on www.digitalfaq.com for my starting point. I've tried to cull as much from that site and this to help me setup and use my puter. But now I need some furthur help.
Also I've been capturing/editing/authoring on my sisters system (below is configuration) and not seen this problem. But on this system I am mainly copying VHS tapes that have the comercials cut during recording. So I don't have to cut comercials which is where I see the periodic problems w/ the ATI AIW7500 recorded files.
I'm using
MPEG-VCR V3.14 (MPEG-2)(06/2004)
25 June 2004
On my system I'm capturing using ATI MMC 8.1 on an ATI AIW7500 using the following parameters:
Format: MPEG-2 SVCD
Standard: NTSC (525)
Resolution: 352 x 240
Audio Format: 44.100Khz, 16 bit, Sterio
P Frames in Group: 4
B Frames in Subgroup: 2
Closed Group of Picture (GOP)
Variable Bit Rate
Max Bit Rate: 2.64
Target Bit Rate: 1.84
Motion Estimation Qual: 99
Audio Bit Rate: 256K Bit/Sec
None-Video Soap type
My system is as follows:
Operating System: Win2k-SP4
CPU Speed: Athlon XP BARTON 2500+
Harddrive space: 80GB ATA 133 MAXTOR
RAM Memory: 512 MB DDR PC2700
Video Card: ATI AIW7500
Motherboard: EPoX 8RDA+
Capture Card: ATI AIW7500
On my Sisters system I'm capturing using WinDVR 3 on an VC100 Video Capture Card using the following parameters:
Mode: MPEG-2
BitStream Mode: MPEG-2 DVD
Video Format: NTSC
Width x Height: 352 x 240
Bit Rate 1300
Frame Rate: 29.97
Aspect Ratio: 4:3
GOP: 15
Sub GOP: 3
Motion Vector:
Horizontal: 16
Vertical: 16
Audio Format: MPEG-1 Layer II
Sample Rate: 48 Khz
Mode: Sterio
Bit Rate: 256 Kbits/sec
My Sisters System:
Operating System: WinXP Home Edition SP1
CPU Speed: Intel Pentium 4 2.40 Ghz
Harddrive space: 80GB Samumg SP8004
RAM Memory: 512MB PC2100 DDR
Video Card: NVIDIA GeForce 2 MX/MX 400
Motherboard: Via P4P400-FL Motherboard
Capture Card: Leadtek VC100 XP Video Capture Card
DVD RW: Sony DVD RW DW-U10A
Any help would be appreciated,
Joe.
Results 1 to 1 of 1
A/V sync problems with an AVI...
By takearushfan in forum Video ConversionReplies: 0Last Post: 17th Aug 2010, 17:41 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
Audio Sync Problems
By mattr in forum MacReplies: 4Last Post: 7th Jul 2008, 09:55 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22
