Hello, Folks:
I'm a newbie when it comes to making VCDs and I have a couple of questions:
1) Can you use DVD-R/Ws to make VCDs or just CD-R/Ws?
2) Which program(s) do you recommend for converting AVI to MPEG, MPEG to VCD and AVI to VCD?
Thanks,
- Bodrey
A VCD must be on a CD (otherwise it wouldn't be a Video CD)...however, VCD video is DVD compliant. That means that you can make an mpeg using VCD resolution (352x240/288) and then author and burn it as a DVD. The major difference is that VCD audio is 44.1 KHz and DVD is 48 KHz. By using VCD resolution and bitrate you can get almost 7 hours on a DVD.
Avi to mpeg, I use TMPGEnc.
Mpeg to VCD, I use VCDEasy.
Avi to VCD, see above.
Mpeg to DVD, I use TMPGEnc DVD Author."Art is making something out of nothing and selling it." - Frank Zappa
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
