Just got this box of tricks.. i remember someone talking before about how you shouldn't use the same signal type for input and ouput.. but when i use composite for either in or out it shows tons of intererence? It's not really a cheap lead either.. what gives?
Use whatever looks best.
Clean the inputs, switch cables.Want my help? Ask here! (not via PM!)
The best thing at the moment is svideo in and out, but as mentioned before this introduces a certain amount of degradation too. The leads i've tried on the composite are a dirt cheap simple phono wire which results in lots of wavy interference and a hi quality shielded ofc which shows less of that but still quitre a lot. They're clean etc.. when i rig it that way i have svideo from the 9800 to the AVT and composite from that to the F1 front input composite connector on the front of the DR-M1.. anything wrong with this? Can't see why i'm getting such a poor signal over composite..
AVT-8710 owners, what settings do you use?
By myoung08 in forum Capturing and VCRReplies: 5Last Post: 27th Jul 2010, 23:10 -
Problems capturing with AVT-8710
By Tafflad in forum Capturing and VCRReplies: 1Last Post: 9th Feb 2010, 07:45 -
Help with AVT-8710 TBC
By Reniamatic in forum RestorationReplies: 2Last Post: 17th Sep 2007, 15:26 -
Panasonic e80h and the AVT-8710
By rmmd in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Sep 2007, 13:03 -
AV Toolbox AVT-8710?
By hip_school_preppie in forum Capturing and VCRReplies: 4Last Post: 30th May 2007, 18:43
