When I try to copy a dvd with nero, right at the end I get these 2 errors
Error reading data
burn process failed at 8x ( size of movie )
I tried changing the speed hoping that would fix it but it did not.
sounds like you are trying to copy a dual layer disk onto a single layer burnable dvd disk ....
or is it a bad source copy with a defect or scratch
try to copy the files to your hard drive first"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Error reading data
did you try to copy to your hard drive first ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you may want to also try using dvd decrypter, which i find the best way to do a straight one to one copy
Well it seems like there is a problem with the one chapter, no program will copy it no matter what I try.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 16:59 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 15:39 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
