  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I just backed up a dvd on a Prodisc R03 disk. When I tested it for errors, @ 99% the last 6-7 blocks had errors. Now what does that mean? I went to the end of the dvd and everything played back fine. Could this error cause the movie to freeze at the end of the movie, if i where to watch the entire thing. I recently watched another movie burned onto a R03 disc and it froze with 5 mins left, but when I did a quick scan after I had burned it, it looked fine at the spot where it now freezes.
    Media Information
    Disc Regions are 1,2,3,4,5,6,7,8
    Media code/Manufacturer ID PRODISC R03
    Media Product Revision Number 03h
    Volume Name 2933jd3343sdf33r3
    Application id
    Implementation id VSO Software CopyToDVD
    Recording Date/Time (mm/dd/yyyy) 8/22/2004 17:05:07
    Format Capacity 4.38GB(4.70GB)
    Book Type DVD-ROM
    Media Type DVD+R
    Media Id Code Speed 8.0x 11080KBps
    Data area starting sector 30000h
    Data area end sector 23053Fh
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    This is the 1st time I went for cheaper media (usually use verbatim/memorex with no problems, 150+ backups) but I couldn't find any printable discs from them. Did I just get bit in the ass for being cheap??
    What We Do In Life, Echoes In Eternity....
