Please be patient, I'm still new to this...
I have captured some video from my tv-tuner card (from the svideo in) using VDub which is interlaced. Now, when I converted the video to VCD format, TMPGEnc seems to deinterlace it. However, when I converted the video to SVCD format, it didn't seem to deinterlace it. So I had to convert again using the deinterlace filter.
Is this correct? Should I be deinterlacing the SVCD to be played on a stand alone dvd player? Should I have deinterlaced the video in VDub? Can it deinterlace?
Thanks in advance.
I'm pretty new to this as well, but I've found lots of useful info in posts and faqs.
Give http://www.geocities.com/lukesvideo/interlacing.html a gander. The rest of his faqs, although centered around capturing and otherwise dealing with animation, are still very informative.
But quoting from near the end of that page, Luke says "... if you're planning to watch your output video on a TV (through an SVCD, for example), it's best to leave your video as interlaced. Essentially, if you're going to watch on tv ... interlace best; if you're going to watch on a computer ... interlace worst.
How can I know if Avi is progressive or interlaced ??
By apalace in forum Newbie / General discussionsReplies: 17Last Post: 8th Feb 2012, 14:20 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
after De-interlaced, what is avi become?
By tinkyawoo in forum EditingReplies: 8Last Post: 19th Jul 2008, 23:01 -
Help with possible interlaced pal avi source
By h2p000 in forum Video ConversionReplies: 4Last Post: 28th Feb 2008, 17:41 -
keep interlaced footage on tmpgenc xpress
By kamaleon in forum Video ConversionReplies: 2Last Post: 6th May 2007, 09:31
