I have been burning DVDs for about a year now and have limit success with MY DVD, DVDit 2.5, Encore and DVD workshop.(One software package will offer one extra that another does not have) What sofware package is the best for under $300 that will create chapter points, motion background and buttons, encoding, etc. Or just let me know what software you use and why you like it.
Len
lhbrown1@bellsouth.net![]()
Results 1 to 15 of 15
Hello,
Tmpgenc dvd author - vob import - bad - only 1 audio track
Ulead Dvd Movie Factory - simple, fast
Kevin
For more choices look under dvd authoring here:
https://www.videohelp.com/toolsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
DVDit! PE will do a lot of mid-level work, with the exception of motion menus and multi VTS.
To get the funtionality of DVDit! PE and the motion/VTS aspect, I recently upgraded to DVD Workshop 2 (but be sure to install all the new updates and patches!).
TMPGEnc DA is newbie software. It is easy to use, sure, but the end product look pretty bad, as the software has poor, poor alias control on the fonts, rendering most fonts unreadable. Aside from converting VCD to DVD, or when dealing with imperfect source, TDA is not very good at all. Just cheap and not picky.Want my help? Ask here! (not via PM!)
So, if you wouldn't suggest TDA, LordSmurf, then what would you suggest that would be good for Newbies but also reliable and works well?
I use tda and find it great for general dvd authoring and i havent found any problems with fonts plus its easy to add mpg1 and mpg2 to separate tracks and all my dvds created from tda play ok.
DVDit! PEOriginally Posted by MelekalWant my help? Ask here! (not via PM!)
I have used Pinnacle Studio 8, Nero Vision Express and most recently Ulead VideoStudio 8. I have also tried a host of others but I like VideoStudio 8 (VS8) the best. VS8 is easy to use, seems to be very stable, produces fairly decent results and renders quicker than most of the of the other authoring programs I have tried. So far, their tech support has been very responsive and helpful. Lastly, they have a free
trial version that is fully functional for 30 days.
wwjd -
I have read the reviews for DVDlab, Ulead DVD factory and DVDit 5.0. Of those three which one gives the most bang for its buck
I am partial (and in the vast minority here) to DVD Architect 2. It's a little pricey, but Vegas 5 is outstanding and DVD-A suits my needs very well.
Give DVDlab a try, its pretty simple to use and you can create some nice looking DVDs with it. I think you can trial it for 30 days.
Ulead DVD Workshop 2.011 may help you (not sure about subs, ulead.com for info). But it's more than $300.
DVDlab pro supports multiple subsOriginally Posted by pchan
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
Does
