i bought few spindles a month ago with nec ND2510a and i had to rma the nd2510a due to some problems.
so i'm looking for replacement. i'm looking at liteon and lg GSA 4120B.
i read on another forum that liteon drive is not very good with Ritek DVD-R, but good with +R
i'm not planning to buy more media until i use my spindles out.
so i'm open to suggestion and recommendation between the above drive or other drives that you guys suggested.
Thank You,
Xo Martel
Results 1 to 9 of 9
I've burned about 300 Riteks on my Liteon 851s in the last few months. Only had 1 or 2 bad burns.
No problems with Ritek G04's on my Pioneer 104 and 105.
Thank you for the replies guys,
i'm going to hunt for better price then between both drives.
anyone would recommend plextor with dvd-r? i think i saw a rebate discount few days ago to come within my budget.
as for ryvius, here is the link regarding on my problem with NEC ND-2510A
https://www.videohelp.com/forum/viewtopic.php?p=1011580&highlight=#1011580
Xo Martel -
nothing but troubles on my Pioneer 107D.
maybe a bad batch? who knows..but I'll never touch them again. -
sounds like you definitely have a bad batch richdvd. I've used hundreds of G04's on my Pioneer 107 and they've all been perfect. Probably the lowest PI/PO error rate among the non Japanese made media.
-LeeBear
DVD writer doesn't work
By kamyogi in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Apr 2011, 11:43 -
Which laptop is the bes for video editing and stuff?
By Kashi169 in forum EditingReplies: 8Last Post: 10th May 2010, 10:30 -
How did the fluke good DVD-Rs from Ritek & Prodisc come about?
By Bix in forum MediaReplies: 3Last Post: 19th Aug 2008, 16:23 -
Prototype HD DVD-R Writer seems to work fine.
By videopoo in forum Authoring (DVD)Replies: 3Last Post: 31st Dec 2007, 18:52 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
