Can anyone tell how do i know that the mpeg files i have had a NTSC format or PAL. And once more can MPEG playable in the VCD. thanks for the replied.
Open up in Vdub, go to File>Information. 352x240 @ 23.97/29.97 fps is NTSC, 352x288 @25fps is PAL.
The reason nobody answered you is probably that you couldn't be bothered to read through the guides first.
There is a bit about ntsc to pal her http://www.vcdhelp.com/pal2ntsc/pal2ntsc.htm
And I suppose to go the otherway one would load the pal template.
Though, I wouldn't call it converting, its more like re-rendering - which will of course loose quality ... but i suppose there isn't much to be done about that.
i suggest PAL becuase it looks better but if you live in the US, or Japan or close to Japan Use NTSC becuase your TV has diffrent format and your picture might look like black and whit and you will get 2 black bars on the side if you use a PAL format on a NTSC TV
....but some new TV support both soo try it with a CDRW first okay
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
