Now when i use svcd2dvd it wont play on nothing but my xbox but it use to play on everything./....i have not chaged tha way i have done anything......BUT NOW it wont even finish converting...it gets stuck & just stays on the part where it says multiplexing...heres a log that i just stopped cause it was taking to long
Starting SVCD2DVD: v1.51.2.0
Begin time: 9:26:20 PM
******** Ripping BIN images to get mpegs (VCDGear -fix)
VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (bin2mpg)
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01.mpg
Fix MPEG Errors
[mvn_coltsr01.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 820457988 bytes [05:38:07]
#searching...
1 track(s).
Setting read size to: 2352
Setting write size to: 2324
# Track 1 -> writing...
# 0%
# 0 MPEG block correction(s) applied
# 0 Blocks padded
# OK!
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr02.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr02.mpg
Fix MPEG Errors
[mvn_coltsr02.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 830000332 bytes [06:32:63]
#searching...
1 track(s).
# 0%
# 2 MPEG block correction(s) applied
# 2 Blocks padded
# OK!
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\vcd_riddickts1.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\vcd_riddickts1.mpg
Fix MPEG Errors
[vcd_riddickts1.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 800569196 bytes [03:43:74]
#searching...
1 track(s).
# 0%
# 0 Blocks padded
# OK!
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\vcd_riddickts2.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\vcd_riddickts2.mpg
Fix MPEG Errors
[vcd_riddickts2.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 759195024 bytes [14:20:32]
#searching...
1 track(s).
# 0%
# 1 MPEG block correction(s) applied
# 1 Blocks padded
# OK!
(Total size: 3102MB, Duration: 00:18:30, Rate(MB/Min): 167.60)
Analysing File: C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01.mpg
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:15.1b]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Error getting mpeg details. (probably due to AC-3 audio)
System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 74.
at System.Xml.XmlScanner.ScanNamedEntity()
at System.Xml.XmlTextReader.ExpandLiteral(XmlAttribut eTokenInfo currToken)
at System.Xml.XmlTextReader.SetLiteralValues(XmlAttri buteTokenInfo fld)
at System.Xml.XmlTextReader.SetAttributeValues()
at System.Xml.XmlTextReader.ParseElement()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
Analysing File: C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr02.mpg
Analysing File: C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\vcd_riddickts1.mpg
Analysing File: C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\vcd_riddickts2.mpg
-->Processing 4 mpeg files
############### New MPEG File ###############
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01_DVD.mpv...
File C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 350615
System headers = 1
Padding Stream packets = 2, total bytes = 2451
MPEG Audio stream 0 packets = 41762, total bytes = 95760091
Video stream 0 packets = 308852, total bytes = 709171296
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01-0.mp2...
Summary:
MPEG Packs = 350615
System headers = 1
(Total size: 782MB, Duration: 00:04:35, Rate(MB/Min): 170.13)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 91MB, Duration: 00:01:19, Rate(MB/Min): 68.91)
******** Trimming start of video ES
- Nothing to do.
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2521200 bits/sec
INFO: [mplex] Vbv buffer size : 131072 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Moviez\Extracted\Movies\Chron & Collad\mvn_coltsr01_DVD.mpa)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : free
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2560248
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 13019
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
System.Threading.ThreadAbortException: Thread was being aborted.
at Microsoft.Win32.NativeMethods.WaitForSingleObject( HandleRef handle, Int32 timeout)
at System.Diagnostics.Process.WaitForExit(Int32 milliseconds)
at System.Diagnostics.Process.WaitForExit()
at ProcRunner.c5b4b7804027a156.160a0bf4de8f6bd0(Strin g d168ac2ed64c4662, String a6a477a49a1a2599, String 450f47a9028f884b, a0efedb9fec1e88f 8b49c96cd0348808, Boolean 74effd3a0f44569e)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
well i changed the folder name & it went all the way thru but it still wont play on ANYTHING besides my xbox. I havent changed nothing I do & havent messed with any settings but it use to play on all dvd players but now it wont....heres tha latest log
Begin time: 10:40:22 PM
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01.mpg
Fix MPEG Errors
# 0%
#searching...
#searching...
1 track(s).
# 0%
# 0 Blocks padded
# OK!
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02.mpg
Fix MPEG Errors
# 0%
#searching...
#searching...
1 track(s).
# 0%
# 2 Blocks padded
# OK!
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1.mpg
Fix MPEG Errors
# 0%
#searching...
#searching...
1 track(s).
# 0%
# 0 Blocks padded
# OK!
Language: English
.bin src(In) -> C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2.bin
.mpg dest(Out) -> C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2.mpg
Fix MPEG Errors
# 0%
#searching...
#searching...
1 track(s).
# 0%
# 1 Blocks padded
# OK!
(Total size: 3102MB, Duration: 00:17:35, Rate(MB/Min): 176.37)
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01.mpg
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02.mpg
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1.mpg
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2.mpg
Type: SVCD
Horizontal Res: 480
Standard: PAL
Audio SampleRate: 44100
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpv.. .
File C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 350615
System headers = 1
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01-0.mp2...
Summary:
MPEG Packs = 350615
System headers = 1
(Total size: 782MB, Duration: 00:05:28, Rate(MB/Min): 142.99)
(Total size: 91MB, Duration: 00:01:42, Rate(MB/Min): 53.48)
- Nothing to do.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpv)
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpa)
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] rough-guess multiplexed stream data rate : 2793048
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] STREAM c0 completed @ frame 142498.
INFO: [mplex] STREAM e0 completed @ frame 85531.
INFO: [mplex] Multiplex completion at SCR=307840438.
INFO: [mplex] Video e0: buf= 69055 frame=085531 sector=00352585
INFO: [mplex] Audio c0: buf= 4096 frame=142498 sector=00047406
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 709171296 bytes
INFO: [mplex] Sequence headers: 4786
INFO: [mplex] Sequence ends : 0
INFO: [mplex] No. Pictures : 85532
INFO: [mplex] No. Groups : 4786
INFO: [mplex] No. I Frames : 4786 avg. size 23606 bytes
INFO: [mplex] No. P Frames : 23801 avg. size 11884 bytes
INFO: [mplex] No. B Frames : 56946 avg. size 5502 bytes
INFO: [mplex] Average bit-rate : 1658000 bits/sec
INFO: [mplex] Peak bit-rate : 2513600 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 95759332 bytes.
INFO: [mplex] Syncwords : 142500
INFO: [mplex] Frames : 142500 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
(Total size: 790MB, Duration: 00:07:20, Rate(MB/Min): 107.49)
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Type: SVCD
Horizontal Res: 480
Standard: PAL
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpv.. .
File C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02.mpg is an MPEG-2 Program Stream
pack header field flag value not allowed in program streams
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02-0.mp2...
(Total size: 791MB, Duration: 00:00:06, Rate(MB/Min): 7,232.00)
(Total size: 4MB, Duration: 00:00:05, Rate(MB/Min): 41.85)
- Nothing to do.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpv)
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpa)
INFO: [mplex] STREAM c0 completed @ frame 7652.
INFO: [mplex] STREAM e0 completed @ frame 4636.
INFO: [mplex] Multiplex completion at SCR=16618349.
INFO: [mplex] Video e0: buf= 47899 frame=004636 sector=00016681
INFO: [mplex] Audio c0: buf= 4096 frame=007652 sector=00002546
INFO: [mplex] Video Stream length: 33521664 bytes
INFO: [mplex] Sequence headers: 259
INFO: [mplex] No. Pictures : 4637
INFO: [mplex] No. Groups : 259
INFO: [mplex] No. I Frames : 259 avg. size 22991 bytes
INFO: [mplex] No. P Frames : 1289 avg. size 9756 bytes
INFO: [mplex] No. B Frames : 3090 avg. size 4850 bytes
INFO: [mplex] Average bit-rate : 1445200 bits/sec
INFO: [mplex] Peak bit-rate : 2066400 bits/sec
INFO: [mplex] BUFFERING min 43 Buf max 134306
INFO: [mplex] Audio stream length 5142820 bytes.
INFO: [mplex] Syncwords : 7654
INFO: [mplex] Frames : 7654 padded
(Total size: 38MB, Duration: 00:00:25, Rate(MB/Min): 88.44)
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpg
Type: SVCD
Horizontal Res: 480
Standard: PAL
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpv ...
File C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 344464
System headers = 1
Padding Stream packets = 2, total bytes = 2745
MPEG Audio stream 0 packets = 41023, total bytes = 94065739
Video stream 0 packets = 303440, total bytes = 696743696
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1-0.mp2...
Summary:
MPEG Packs = 344464
System headers = 1
(Total size: 763MB, Duration: 00:06:55, Rate(MB/Min): 110.16)
(Total size: 89MB, Duration: 00:01:33, Rate(MB/Min): 57.42)
- Nothing to do.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpv )
INFO: [mplex] Bit rate : 2556000 bits/sec
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpa )
INFO: [mplex] rough-guess multiplexed stream data rate : 2828400
INFO: [mplex] Scanned to end AU 84015
INFO: [mplex] STREAM c0 completed @ frame 139976.
INFO: [mplex] STREAM e0 completed @ frame 84015.
INFO: [mplex] Multiplex completion at SCR=302382811.
INFO: [mplex] Video e0: buf= 38162 frame=084015 sector=00346434
INFO: [mplex] Audio c0: buf= 4096 frame=139976 sector=00046567
INFO: [mplex] Video Stream length: 696743696 bytes
INFO: [mplex] Sequence headers: 4749
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 84015
INFO: [mplex] No. Groups : 4749
INFO: [mplex] No. I Frames : 4749 avg. size 26996 bytes
INFO: [mplex] No. P Frames : 23429 avg. size 12259 bytes
INFO: [mplex] No. B Frames : 55838 avg. size 5037 bytes
INFO: [mplex] Average bit-rate : 1658400 bits/sec
INFO: [mplex] Peak bit-rate : 2558400 bits/sec
INFO: [mplex] BUFFERING min 17 Buf max 134306
INFO: [mplex] Audio stream length 94064548 bytes.
INFO: [mplex] Syncwords : 139978
INFO: [mplex] Frames : 139978 padded
(Total size: 776MB, Duration: 00:07:51, Rate(MB/Min): 98.81)
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpg
Type: SVCD
Horizontal Res: 480
Standard: PAL
Saving stream 0xE0 into file C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpv ...
File C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2.mpg is an MPEG-2 Program Stream
Summary:
MPEG Packs = 326617
System headers = 1
Other stream 0x0B packets = 1, total bytes = 8850
Other stream 0x0E packets = 1, total bytes = 10900
Other stream 0x13 packets = 1, total bytes = 17357
Other stream 0x15 packets = 1, total bytes = 9004
Other stream 0x1A packets = 2, total bytes = 28204
Other stream 0x1D packets = 1, total bytes = 8852
Padding Stream packets = 2, total bytes = 2476
MPEG Audio stream 0 packets = 38900, total bytes = 89197700
Video stream 0 packets = 287716, total bytes = 660639518
Saving stream 0xC0 into file C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2-0.mp2...
Summary:
MPEG Packs = 326617
System headers = 1
(Total size: 724MB, Duration: 00:06:02, Rate(MB/Min): 119.94)
(Total size: 85MB, Duration: 00:01:34, Rate(MB/Min): 54.07)
- Nothing to do.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Scanning for header info: Video stream e0 (C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpv )
INFO: [mplex] Scanning for header info: Audio stream c0 (C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpa )
INFO: [mplex] Scanned to end AU 79667
INFO: [mplex] STREAM c0 completed @ frame 132730.
INFO: [mplex] STREAM e0 completed @ frame 79667.
INFO: [mplex] Multiplex completion at SCR=286729947.
INFO: [mplex] Video e0: buf= 46534 frame=079667 sector=00328531
INFO: [mplex] Audio c0: buf= 4096 frame=132730 sector=00044157
INFO: [mplex] Video Stream length: 660639518 bytes
INFO: [mplex] Sequence headers: 4479
INFO: [mplex] No. Pictures : 79667
INFO: [mplex] No. Groups : 4479
INFO: [mplex] No. I Frames : 4479 avg. size 28380 bytes
INFO: [mplex] No. P Frames : 22185 avg. size 12298 bytes
INFO: [mplex] No. B Frames : 53004 avg. size 4918 bytes
INFO: [mplex] Peak bit-rate : 2371200 bits/sec
INFO: [mplex] Audio stream length 89195236 bytes.
INFO: [mplex] Syncwords : 132732
INFO: [mplex] Frames : 132732 padded
(Total size: 736MB, Duration: 00:06:50, Rate(MB/Min): 107.63)
Analysing File: C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpg
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\SVCD2DVD\dummymenuNTSC.mpg...
STAT: Processing C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr01_DVD.mpg.. .
!!!: GOP is not closed on cell boundary (may be non seamless)
STAT: Processing C:\Program Files\FlashFXP\Moviez\Chron\mvn_coltsr02_DVD.mpg.. .
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
!!!: Forced to truncate audio channel 1 gap from 140400 to 13019
Creating VTS #2
-->: VTS 02
STAT: Processing C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts1_DVD.mpg ...
STAT: Processing C:\Program Files\FlashFXP\Moviez\Chron\vcd_riddickts2_DVD.mpg ...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
!!!: Forced to truncate audio channel 1 gap from 115920 to 13019
-->: DVDFolders creating table of contents
scanning C:\Program Files\FlashFXP\Moviez\Chron\VIDEO_TS/VTS_01_0.IFO
scanning C:\Program Files\FlashFXP\Moviez\Chron\VIDEO_TS/VTS_02_0.IFO
-->: Creating menu for TOC
STAT: Processing C:\Documents and Settings\TeEdIzZeL\Local Settings\Application Data\Badgersoft\DVD MenuMaker\1.0.1605.17877\05d54996-3809-4541-85d7-f34b38580d0d\menu.mpg...
(Total size: 2342MB, Duration: 00:17:47, Rate(MB/Min): 131.69)
============ Complete ============
============ Duration: 01:22:04
"attention chrissy boy" Update message shown whilst burning.
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Jul 2010, 11:36 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
Netframework problem Chrissy
By sc0tsman in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 19th Sep 2007, 17:08 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
