I've been at the business of capturing old VHS tapes for a while now. By way of reference, I'm using the Pinnacle DC10+ capture card with Studio 7. I've got a Pentium 4, 3.2Ghz with 120 gig hard drive and Windows XP. Generally speaking, the older the tape the more dropped frames I have. I've tried all the usual stuff - dropping the bit rate on the capture, etc. - with mixed success. For example, I just captured 50 minutes of an old show by The Who and had 248 dropped frames which makes a lot of it pretty unwatchable. My question is that the DC10 has both digital AND analog inputs. Would I get better results if I buy some sort of converter to route the analog video output from the VCR to the converter and then output it to the PC through the Digital input?
Or should I just declare defeat and get a better capture card which would give me fewer dropped frames?
Appreciate any advice
I have a DC10+ as well with Studio 7 and I experienced the same sort of numbers of dropped frames. It didn't matter whether the tape was brand new or 10 years old. I bit the bullet and bought an ADVC-100, which has not dropped any frames whatsoever on the exact same tapes.
If in doubt, Google it.
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02
