Hello I'm trying to convert one movie on two files that has ac3 audio with tmpgenc 3.0 express. When i open the files tmpge sees the audio. Before i start the converion i always look at the preview, and this time it gives me "Invalid sample format (error code 0x80048002)". So using virtualdub i extracted it to wave and opened them as the audio. This time in the preview i see the video but without audio. I have done a movie with the filmmachine but it takes more than twice as long. Please help I really hope there is a way to do it with tmpge. Thanx
I presume you're using "Full Processing Mode" when you extract the .wav? If you don't, it'll simply be a mislabeled .ac3 file.
Use VirtualDubMOD, load the AVI and go to Streams->Stream List-> Demux. Save that .ac3 file and encode video only in TMPGEnc to .m2v elementary stream, and put the two (audio and video) together at the authoring stage. That oughta work for you.
Unless, of course, the AVI itself is screwed up, a common occurence.
Pull! Bang! Darn! -
Thanx fritzi, everything woked great untill the authoring stage. After the conversion I have one video file, but two audio. How can I demux both audio to one file, or join the two?
Got it, file "append segment" to join the two avi files in virtualmod then do the rest and bang! Thanx again
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 03:25 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 03:38 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Make an xvid/avi from DVD but keep original ac3 surround sound?
By coolchris in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 07:35 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 15:16
