Hi.
I'm using virtual dub to frame serve to CCE. I need to resize from 720x480 to 480x480 AND apply the inverse telecine from the 'video/frame rate' menu. What I need to know is the order in which Virtualdub is going to do this. I appears from looking at the preview in the filter that the resize is going to be done first, then the inverse telecine, but I need to know for sure, so I can determine if I should click the interlace box on the resize filter. Thanks!
<font size=-1>[ This Message was edited by: jbarman on 2001-11-21 11:22:07 ]</font>
