Hey everyone,
how exactly do i go about ripping audio from a dvd. i had instructions and which involved ripping the video with Smart Ripper and then using Graph Edit (or something like that) to extract the audio into a wav...however now when i try to rip the dvds it will not work. i get a message saying
"No ASPI-Adapter Availble" when i boot up the program... i click okay and it opens the dvd, but when i hit "rip" i get this message...
"No keys found to this encrypted file!"
:: ehmjay.
Try use DVDDecrypter, see if you get the error again.
JMO, Smartripper mightbe a bit complicated/confusing if you're not familiar with the program. -
The thing is i used to always use Smart Ripper but ever since i upgraded to Win XP (pro) i've had troubles with it.
:: ehmjay. -
Well, every time I used Smartripper, the "No ASPI-Adapter Availble" always appears, but about 5 to 10 seconds later the files would unlocked and I can start ripping whatever way I want.
Anyway, have you try DVDDecrypter yet?
By tduck7 in forum AudioReplies: 2Last Post: 17th May 2010, 16:29 -
Ripping Audio off DVD
By alimustafakhan in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jun 2009, 18:28 -
Ripping and Keeping HD Audio
By SeeManRun in forum AudioReplies: 0Last Post: 27th May 2008, 00:00 -
audio ripping
By zinc in forum AudioReplies: 3Last Post: 24th Apr 2008, 15:41 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
