I've just got the Panny DMRe55.
Is there a simple way to copy a panny recorded ram disk (using nero) onto a dVD-R, so that it appears to the player as though it has recorded the disk itself (and hence can add more programs, finalise etc)
If this is not possible, I can still use womble to edit the file, and create a dvd afterwards, but would like the previous method as well.
I've tried everything to copy RAMs from a Panasonic to DVD-R, no luck. If you figure it out I would really like to know how you did it.
The problems that do arise from getting a RAM recorded disk to PC for editing and producing a final dvd-r or +r for that matter, (my panny seems to read everything ok, NTSC that is).
I use flexible recording alot, to make sure I do not miss a late running ending. Is it possible that this very option creates files which cannot be imported to TempC Author for instance?
It comes up with a red text message saying Illegal vidoe file.
This only happens sometimes, I then have to re-encode the flipping thing, which is a darn shame.
Help anyone?PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Hi
I record a lot to Ram on my E50 and then copy it to DVD-R on the PC after editing etc, with no problems. I use TEMPGEnc DVD Author to transfer the Ram files onto Pc and use it to edit, add menus and then for authoring, then i either use it's burning tool (very good) or Nero to burn DVD-Rs.
victoriabears -I use flexible recording alot, to make sure I do not miss a late running ending. Is it possible that this very option creates files which cannot be imported to TempC Author for instance?
Hammy
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32 -
Copy recorded DVD-RAM to DVD-RW?
By Trollheart in forum MediaReplies: 11Last Post: 15th Apr 2008, 14:32 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23 -
Is there way to copy a Dvd realtime with RAM drive like a standalone playr?
By Blumphf in forum DVD RippingReplies: 18Last Post: 25th May 2007, 06:21
