  1. Hi, Newbie here.
    Learning curve is going OK for burning.
    A fair number of coasters, but thats OK this week.
    Several questions, some are linked and some are free standing.
    Would love any help at all with these.
    Feel free to email me if you'd like.
    The sooner I know, the sooner I can help others.
    1) Can a 3.4G commercial DVD be ripped using DVD Backup and then the resulting Video_TS folder be used with Disc Imager and then burned with Disk Utility?
    (I do not have DVD2one as of yet and was not sure if I need to use for such a small DVD file 3.4G.)
    What did do was..
    Load DVD.
    Scanned each chapter for several seconds with DVD player.
    (per Galactica tutorial for newbies. Minus the DVD2oneX part).
    Closed DVD player.
    Opened DVD BackUp
    Processed the disc.
    Dragged the resulting Video_TS folder to Disc Imager.
    Open Disc Utility, clicked 'burn'. choose the .img file that Disc Imager created and started the burn.
    Verified.
    Plays on iMac and eMac.
    Won't play on home player.
    I am using Maxell Yellow DVD-R 4.7G discs.
    That is what I did and ended up with a disc that plays on my eMac and iMac but not my home player.
    The home player is a Panasonic S35, it almost plays the disc.
    The 'play' window starts but then goes to 'stop'.
    So, is it my technique, the media, the player ?
    Thanks Again for the help.
    I have been able to burn several successful discs already.
    Best Rocco
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I suggest that if you dislike SPAM, remove your e-mail address from this post (using the edit button) and replace it with a "PM me here"
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Hi, newbie!
    if the disc plays fine on your home computer, but does
    not on your standalone player, chances are that the
    player does not like DVd-R media.
    Have you checked the
    "DVD Player" compatability link over on the left
    to see how your home player rates?
    It can often save you headache, as many have posted
    their results with specific players.
    Now, my only other question:
    Have you tested this same VIDEO_TS with the
    supplied Apple DVD-R that came with your imac or emac?
    ( you should have gotten a free blank DVD-R
    with the purchase of your computer, with your
    system discs.) Test using that and report back.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  4. Yes Sir, Thank You Sir. I appreciate the heads up on the spam warning.
    I will check to see if I have the Apple DVD-r and try that and report back.
    And no I forgot to check the compatibility chart and will do so now.
    Thanks, I greatly appreciate the push in the right directiopn
    ACR
  5. also- Toast is your best friend- it's not just good with burning disks and keeping you from having coasters... it also tastes delish w/ some jelly.
    "What's a matter Colonel Sanders???? CHICKEN???!!!!
