Hi,
I tried backing up a new movie over the weekend. The DVD Rebuilder encoded completely and also rebuilt it. But here's the bad news. When I open the VIDEO_TS files, the sound is clear but the picture is all messed up. It has all different colors, but the sound is perfectly ok. I also burnt it to a RW to check on my DVD player as well. But the same problem as well. The color has some kind of purple tinge. No picture is visible. The original file runs absolutely fine.
Any suggestions?? Is it some setting that messed up. Here's my set up:
CCE Basic: 2.69.01.04
Avisynth 2.54
RB: 0.52
What movie it is? Region?
What is it the structure of th original? How many MB have the menues, the main movie (video, audio), the extras?
If you do not know how to get that info you can try opening the ripped DVD files in your HD with DVDShrink and change the compression settings to "No Compression"
The same info from the Rebuilded files.
After the Prepare step, what were the reported bitrates (min/max/avg)
PabloNewbie to DVD backup -
The movie was 'Kissing Jessica Stein', a Region 1.
This was the original structure: Menus 35 MB and the main movie 5696 MB. This had 4 audio tracks. When I started DVD RB, i removed two of them. This is what I had after RB. The TS folders had about 3.2 GB and the VIDEO_TS was about 3.5 GB.(not sure of the exact numbers as I had to the delete the RB files because of space limitations on my PC
). After the prepare steps, I had not noted down the bit rates. I will make a note of it the next run.
Thanbks for the response. -
You've got a messed up DLL somewhere, or a bad configuration for one of the DVD-RB components. This happened to me a while back, but starting over from scratch and re-configuring DVDRB fixed it.
- Gurm
colors out of alignment with bd rebuilder
By maca in forum Blu-ray RippingReplies: 2Last Post: 19th Dec 2011, 00:04 -
Purple Screen of death
By Jericho14 in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2010, 04:40 -
FFdshow DivX 3 MP43 + Purple Marks
By Baharroth in forum Capturing and VCRReplies: 1Last Post: 26th May 2009, 08:31 -
Playback on computer: Purple Haze
By tempac in forum Video ConversionReplies: 7Last Post: 13th Mar 2008, 16:00 -
Colors getting purple after conversion
By vertical in forum Newbie / General discussionsReplies: 3Last Post: 5th May 2007, 22:30
