I have an NTSC DV source that I want to put on a DVD. I don't want to modify the AR. I just want it to fill a normal AR TV. I accept the overscan as being normal.
Using the wizard it picks:
4:3 525-line (NTSC, 704x480)
Is this the right for my purposes? Given the source is DV (720)?
John
I always use Full Screen(Keep aspect Ratio).
Think thats what I was told a while back. -
I have worked strictly with 740x480 DV source. TMPGENC always seems to default to 704x480. I switch it to what I know is the correct source. However, I have forgotten to do this on a number of occassions, and saw no difference in the output. I think the key with this setting is the aspect ratio 4:3, not the actual pixel values. Both have the correct aspect ratio and it seems to work fine.
aspect ratio problems using fairuse wizard with x264
By scarlac in forum DVD RippingReplies: 10Last Post: 13th Jul 2009, 11:01 -
Some VOB's not displaying the correct aspect ratio
By Browncoat in forum Media Center PC / MediaCentersReplies: 26Last Post: 20th Mar 2009, 03:57 -
Correct aspect ratio
By dfisher052 in forum DVB / IPTVReplies: 8Last Post: 26th Oct 2008, 00:34 -
How to correct the aspect ratio (I see it in 4:3 but it should be 16:9)?
By Anonymous74 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2008, 08:10 -
how to correct the aspect ratio of AVI
By edong in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2008, 19:04
