I have two existing VOB's that I am adding to my home video. This is the process I am currently using:
1) Convert the 2 vob's to .avi using VirtualdubMod.
2) Import .avis into TMPGEnc and convert to m2v.
3) Transfer home video and convert to m2v using TMPGEnc.
4) Use virtualDub to demux --->wav
5) Use ffmpeg to convert from wav to ac3
6) Use TMPGEnc DVD Author to author everything.
7) Nero to burn
Does anyone see any potential way I could lose any picture/sound quality with the way I'm putting my dvd together? Or, are there any redundant steps in my process? The output seems to be ok, but after looking at video on your monitor and tv for so long at one sitting, it all starts to look the same.
Results 1 to 15 of 15
I would eliminate Step 1 and frameserve with DVD2AVI, then import the D2V file into TMPGEnc Plus. This can also demux which eliminates step 4.
If in doubt, Google it. -
this is the type of input I was hoping for. I don't think my method is the most efficient way, but the end result, long as it may be, turns out fairly well. I am just hoping to cut out anything I am doing that I dont need to be, and hopefully, come up with a fast, consistent method. Thanks for all the great input.
You are losing quality by re-encoding a video that
is already encoded, and taking lots more time.
TDA will take VOBs directly. I just did it. -
Originally Posted by jimmalenko
Edit: Foo beat me to it."Art is making something out of nothing and selling it." - Frank Zappa -
I think TDA has issues if the vob's have difft audio or video schemes though, no?
Originally Posted by Noek"Art is making something out of nothing and selling it." - Frank Zappa
yes, and I think this is where I ran into some difficulty with the way I was setting up my DVD. I have two intros that play when the dvd is inserted. No menu. I think on seperate tracks, it wouldn't auto play the two intros before jumping into the movie. Maybe I just didn't play around with it long enough though /shrug
Moved to DVD Authoring forum
7) Nero to burn
Its alot faster than vdub for audio extration.
how do I replicate the technique used in this video
By edinzec in forum EditingReplies: 13Last Post: 1st May 2012, 13:32 -
dvd stuck in dvd player - best removal technique?
By ChaunceyK in forum Off topicReplies: 9Last Post: 22nd Mar 2010, 20:07 -
questionI was wondering... If I want to connect my cable line to a HDD DVD
By SIGNAL_4 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Oct 2009, 13:45 -
just wondering - can normal dvd player hack to play hd-dvd
By chanra in forum Newbie / General discussionsReplies: 16Last Post: 12th May 2009, 22:00 -
What is a good xvid, avi cutter (for unwanted commercials) w/batch process?
By kbal in forum Video ConversionReplies: 5Last Post: 20th Dec 2007, 10:34
