lately I do have the problem that all my img and iso files fail to write using dvd decrypter or nero. when I extract them to the harddisk and then add them to nero using the dvd video project it works perfectly. although nero gives a reallocation error (it hates the 0KB vob files) it burns them and the dvd+r play on all possible players and the pc.
it used to work with dvd decrypter before and I dont know why I have to go through lenghts to extract them first nowadays to make it work. any idea?
below the nero log;
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\CD.Mastering\Burners\Nero\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16.12.2003 20:18:06
Nero version: 6.3.1.17
Recorder: <PLEXTOR DVDR PX-708A> Version: 1.07 - HA 0 TA 0 - 6.3.1.17
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PLEXTOR DVDR PX-708A >Version: 1.07 - HA 0 TA 0 - 6.3.1.17
=== Scsi-Device-Map ===
CdRomPeripheral : PLEXTOR DVDR PX-708A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TDK CDRW401248B atapi Port 0 ID 1 DMA: On
DiskPeripheral : IC35L080AVVA07-0 atapi Port 1 ID 0 DMA: On
DiskPeripheral : WDC WD800BB-32CCB0 atapi Port 1 ID 1 DMA: On
DiskPeripheral : ST380013AS 3.18 UlSata Port 2 ID 0 DMA: Off
DiskPeripheral : Maxtor 6Y250M0 YAR5 UlSata Port 2 ID 2 DMA: Off
DiskPeripheral : Maxtor 6Y200M0 YAR5 UlSata Port 2 ID 4 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
PLEXTOR DVDR PX-708A N: CDRom0
TDK CDRW401248B M: CDRom1
AXV CD/DVD-ROM X: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2046MB (2095592kB)
Free physical memory: 1288MB (1318968kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.8.2004
Burn DVD Image
15:27:48 #1 Text 0 File Reader.cpp, Line 118
Reader running
15:27:48 #2 Text 0 File Writer.cpp, Line 124
Writer PLEXTOR DVDR PX-708A running
15:27:48 #3 Text 0 File Burncd.cpp, Line 3172
Turn on Disc-at-once, using DVD media
15:27:48 #4 Text 0 File DlgWaitCD.cpp, Line 245
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2267740 (503:56.40, 4429MB)
15:27:48 #5 Text 0 File DlgWaitCD.cpp, Line 257
Write in overburning mode: NO (enabled: CD)
15:27:48 #6 Text 0 File DlgWaitCD.cpp, Line 2137
Recorder: PLEXTOR DVDR PX-708A, Media type: DVD+R
15:27:48 #7 Text 0 File DlgWaitCD.cpp, Line 418
>>> Protocol of DlgWaitCD activities: <<<
15:27:48 #8 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2267741 (2267741) = #2267741/503:56.41
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2267741 blocks [PLEXTOR DVDR PX-708A ]
15:27:48 #9 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [PLEXTOR DVDR PX-708A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4644333568, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2267741 | lead-out | 1 | 0x00 | 0x41
15:27:48 #10 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
15:27:48 #11 Text 0 File Burncd.cpp, Line 4182
Cache writing successful.
15:27:48 #12 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
15:27:48 #13 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 4x (5'540 KB/s)
15:27:48 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:27:48 #15 SCSI -1066 File Cdrdrv.cpp, Line 1188
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03416000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
15:27:48 #16 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 14:11,035 (851035ms) -> OK
15:27:48 #17 Text 0 File DVDPlusRW.cpp, Line 613
Start write address at LBA 0
DVD high compatibility mode: Yes
15:29:07 #18 SCSI -1135 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03A50000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x07
CDB Data: 0x2A 0x00 0x00 0x02 0x1A 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x05 0x1A 0xC0 0x0A
0x00 0x00 0x00 0x00 0x0C 0x07
15:29:07 #19 CDR -1135 File Writer.cpp, Line 304
Write error
15:29:07 #20 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
15:29:07 #21 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
15:29:15 #22 Phase 127 File dlgbrnst.cpp, Line 1845
Generating DVD high compatibility borders
15:29:31 #23 SCSI -1176 File Cdrdrv.cpp, Line 1188
Sense Code: 0x72
Sense Qual: 0x02
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x02 0x28 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x02
15:29:31 #24 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
15:29:31 #25 Phase 129 File dlgbrnst.cpp, Line 1845
Generating DVD borders completed successfully
15:29:31 #26 Text 0 File dlgbrnst.cpp, Line 1703
15:29:31 #27 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 4x (5'540 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28.10.2003 12:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=86912 bytes, created 31.03.2003 14:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I dont think its the media since I used different media types and it works when the images are extracted.
any input?
Just to be sure, try ripping one of newer original (whatever is in the best shape) to an ISO with decrypter and see if you still have the same issues when you try to burn it.
Nothing can stop me now, 'cause I don't care anymore. -
to out myself as a lamer, I havent bought or ripped anything myself in years. I get all my stuff from topsites. the files are impecable though, they burn fine on other systems. must be something on my side.
just for fun i installed recordnow max and even though using the conventional manual way it fails using this tool as well, when using the wizard it burns the dvds and they play fine. how's that for a riddle?
Originally Posted by hypersucker
stick to what is legal and you will have fewer problems. -
ye rite. and everyone else is just making backups of their existing dvd collection *cough*
I own all licences for every piece of software on my pc's and all the hardware is legit.
neway, i think i'll work around this problem for now. -
Listen hypersucker,
You have already admitted warez.
You won't get any help.
Maybe you should buy the movie and quit attacking other members.
We are here for a varity of reasons...
Some people convert home movies into dvds. Others back up dvd's.
Ok..... -
Reminder:
Warez are against the forum AUP. Please do not discuss them, or you will recieve a formal warning.
hypersucker, you may or may not be talking of warez. Bear this informal warning in mind when you next post please.
Writing fail with Img Burn
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 04:02 -
.iso, .img, .cue, etc. to DVD
By Xandal in forum ComputerReplies: 5Last Post: 26th Aug 2008, 11:52 -
Problem with .IMG/.ISO file
By macamba in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 03:57 -
IMG/ISO to DVD
By digitalred93 in forum Newbie / General discussionsReplies: 7Last Post: 28th Nov 2007, 22:59 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 14:13
