Im compiling a DVD set of The Sopranos is it best to shrink each episode before using TMPEG DVD AUTHOR i.e. each episode shrunk first or compile all the episodes and run them through DVD AUTHOR then use DVD Shrink anyone have an idea which is best?
For me, the best it's after authoring because your menu will take some place.
If your files are > 4.3 gb then you probably need Tmpg dvd author 1.6 which supports DL. -
Thanks cd when i convert each episode to dvd format the file size is usually around 3.5gb so u have an idea of the scale size of the overall DVD so DVD SHRINK has a lot of work to do and also the proccessor
Originally Posted by fahrenheit1
Sopranos episodes range in length from 50 - 65 minutes. The PAL box sets for season 3 and 4 had three episodes to a disk, with 4 episodes on the final disk of the set.
Using DVD/RB/CCE I was able to get a good quality backup of the 3 episode disks, but for the 4 episode disks I split them in two.
If you are willing to wait for multi-pass VBR at fairly tight rates, you should be able to get at least 2 and maybe 3 episodes onto a single layer disk without having to resort to shrink afterRead my blog here.
Each episode is approx 1 hr long i downloaded season 5 but i was given season 3 and on the first disc theres 7 episodes and perfect quality ( which i think is pretty good)
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 06:30 -
Audio Issues in DVD Shrink Re-Author
By mpalm887 in forum DVD RippingReplies: 5Last Post: 21st Jan 2008, 15:28 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 16:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 00:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31
