i have two mpeg i want to make one. how can i make it one mpeg. what progam is the best to edit/cut/and so on....... my videos?
thanks
Hello,
One program to try:
tmpgenc
Go to file - mpeg tools - merge and edit.
Kevin
Others to use---- https://www.videohelp.com/toolsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Another One I've used is Womple MPEG Video Wizard.... very easy to stich two MPEGS together.
https://www.videohelp.com/tools?tool=469#comments
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
