    Nov 2003
    TENERIFE
    I don't know what has happened to my computer(imacG4 17")it won't burn onto DVDs that i have been using for over a year(PRINCO)i know there cheap and crappy but they worked fine.Now aswell my computer won't read DVDs that i recorded before on this computer,whats going on! Do i have a bug or something?.
    Any help would be greatly appreciated.
    scott
    TAKE IT,BUT TAKE IT EASYYYY....
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    You said it yourself, they are cheap and crappy.
    PRINCO disks use a dye that is lower grade than even dye's in ball point pens. These days you can get great disks [Ritek] for well less than what you probably got these PRINCO's for
    The dye degrades and there goes your chances of burning to them or reading disks that have been burned before.
    Its like expecting a plastic hammer to work on metal nails. Sure in the beginning it might work but after a while it just doesnt hold up
    get yourself some more reliable media, Ritek's, TDK's etc
    Nov 2003
    TENERIFE
    cheers mate i'll do that
  4. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    It's also possible that your DVD drive is dying. I'd suggest getting it replaced if it's still under warranty, or trying a different drive if you have access to one. First and foremost, however, stop using the crappy Princo media.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  5. Member decay's Avatar
    May 2004
    i have seen DVD drives that only partially work.
    turns out there are 4 lasers in there; read CD, write CD, read DVD, write DVD. 1, 2, 3 or all of them can stop working. so you might have a drive that reads & burns CDRs, but won't deal with DVDs.
    dk
    Jan 2004
    Finland
    dk
    There aren't really four of them, since same unit is used for reading (at low power) and writing (high power). There maybe two, for CD and separate for DVD, but it's nowadays usually combined. It's some kind aperture trick or other optical thing that only one laser and lens can be used.
  7. Master of my domain thoughton's Avatar
    England
    dk
    FWIW, I've got a CW-8121 combo drive from a powerbook in the cupboard that no longer reads or writes CDs, but the DVD part works fine.
    Which reminds me, can anyone suggest a half-height external firewire housing that would fit a slot-loading combo drive?
    Tim Houghton
    Website • Photography
