  1. hey all, I use ulead dvd moviefactory 3 to create my dvds. But I just notice that I can't skip to the next chapter, I have to press on menu to pick a chapter. Why can't I skip, can someone help me solve the problem, thanks alot
  2. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Because you have them set up as different tracks, not chapters. It'll go normally to the next track at the end of playing, yes, but chapter advance wont help you. If you're making yoru own DVD menu etc...I've found something that helps a lot is...
    Make an image or Video_TS folder of the DVD. Then, use TMPG author, to import a DVD image, and have it copy the .mpeg stream to your Hd. This remoevs all chapter info, then import that MPG into Ulead, and add your own chapters.
    Seth
