I right click a media type filename in 2xExplorer or Explorer to use the Open With command. Zoom Player will not show in the context menu. The place for the name in the list is blank.
To get the name "Zoom Player" to show in the context menu: 1. Open RegEdit. 2. Select Edit|Find... and type "zplayer" in the Find what text control. Click Find Next button. 3. Expand the tree view to show "shell" key. In the right pane will be the Value name "FriendlyCache". 4. Type "Zoom Player" in the Value data text control.
There ya go.
Results 1 to 1 of 1
foobar2000 1.1.3: context menu only on some folders - why??
By flashandpan007 in forum Software PlayingReplies: 5Last Post: 19th May 2013, 10:29 -
MediaInfo Context Menu
By drgt in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2011, 15:48 -
R-click context menu for VLC and WMP - not working
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 07:44 -
[Vista] Sound file context menu/other issues
By Ai Haibara in forum ComputerReplies: 0Last Post: 4th Mar 2009, 01:40 -
Item missing from Windows Context Menu
By alegator in forum ComputerReplies: 4Last Post: 19th Sep 2007, 17:12
